If SPA302DKIT-G1 is compatible with Cisco Business Edition 6000 ver 9.1?
agarciac2010
Pls your help
I Want to know if SPA302DKIT-G1 is compatible with Cisco Business Edition 6000 ver 9.1?
Best Regards.
Armando Garcia
Jaime Valencia
None of the SMB products are tested for compatibility against CUCM enterprise, I believe only a couple worked with the CUCM 3K.
It will be considered a 3rd party in regards to CUCM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
