Integrated Messaging - Default Certificate Error
Luis Giraldo
Beginner
Beginner
I have https enabled on my UC520, and there are self-signed certificates in both the UC520 and Cue.
When I log in through CUE Web admin, to configure Integrated Messaging, I get an error when trying to enable SSL for the connection security.
The error is: "Integrated Messaging: No default certificate selected."
Any idea how to resolve this issue?
Luis
Marcos Hernandez
Collaborator
Collaborator
Luis,
Log into the CUE CLI and do the following:
10.1.10.1# show web session security keylabel
Key Label Is weex-https
10.1.10.1(config)# service imap
10.1.10.1(config-imap)# session security keyLabel weex-https
10.1.10.1(config-imap)# session security mixed
Restart(no enable&enable) IMAP service for the new config to take effect.
10.1.10.1(config-imap)#no enable
10.1.10.1(config-imap)#enable
10.1.10.1(config-imap)#end
10.1.10.1#wr
Let me know how it goes. By the way, if you are trying to use Entourage with IMAP, you might find issues.
Marcos
Marcos Hernandez
Collaborator
Collaborator
Luis,
10.1.10.1#wr
Marcos
Thanks Marcos! That solved the issue.
Luis
