Intersite calls - audio stopped transmitting after 8.2.0 upgrade
dlandriscina
I seem to be having an issue that my intersite calling audio both recieving and sending has stopped working after the 8.2.0 upgrade - has anyone else had this issue?
I tested it both going from an 8.2.0 site to a 8.1.0 then proceeded to upgrade to 8.2.0 at both and still no luck.  The dial plan works and the calls make it through but there is no audio.  Any help is appreciated.
Also unrelated side note - it seems that I also had to change my DTMF settings on a few of my dial peers (AA and CUE VM) as it was not recognizing keystrokes both for external and internal calls.
Thank you
5 Replies 5
David Trad
Hi dlandriscina,
Can you post the configuration (With all sensitive data) from both sites please as text files so we can look into it, we would most likely need to see if the firewall rules are in place to handle this.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David here you go ,
Site A
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname AVE-X
boot-start-marker
boot system flash:/uc500-advipservicesk9-mz.151-2.T2
boot-end-marker
no logging buffered
enable secret 5 REMOVED
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-458160292
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-458160292
revocation-check none
rsakeypair TP-self-signed-458160292
crypto pki certificate chain TP-self-signed-458160292
certificate self-signed 01
  30820249 308201B2 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34353831 36303239 32301E17 0D303931 31313631 34333730
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
   532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3435 38313630
  32393230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  AB0DDC9C 2C91C675 1885B1C9 32AC749B 160A87C7 06A90303 69F10D87 44E26971
  3F2B8391 F35ECFDE 58113B1A 14015C8B 67EA32DE 9953DA5A 253821E4 ED3C3828
  29C4EC49 7CC3946D 633568F7 AC13A092 2A17D01A CEEA2EE3 8FC4A25B F80135C6
  1F675B36 AB1E6318 C95C469C 2A332D09 81BAC21F 7D5356A6 1231D77F 1EC44087
  02030100 01A37330 71300F06 03551D13 0101FF04 05300301 01FF301E 0603551D
  11041730 15821341 56452D58 2E36352E 34342E32 35312E31 3730301F 0603551D
  23041830 168014A8 180F8D4C B59779FA A857A3BE ED09DCE3 8264DC30 1D060355
  1D0E0416 0414A818 0F8D4CB5 9779FAA8 57A3BEED 09DCE382 64DC300D 06092A86
  4886F70D 01010405 00038181 0057ADB2 86D41424 21CC8472 E3DAB646 88190AA3
  C30A6062 B1EC5DB4 AEC942F9 F809DF74 871703AB 33AB43FA 936437D6 BB76B24E
  98390FDF 6EB8A964 D1C5C9B4 570FF099 ECD9BC21 22FBEC55 2CB573A8 B8102DBB
  FF710D14 9084CB29 A7C4E238 4FAB2CB6 CB4D45FC 2F072A62 002CA93A 01FDFD10
  2BE84D39 F00D0DBA 18C1551A 4A
   quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 10.10.10.241 10.10.10.255
ip dhcp excluded-address 10.10.10.1 10.10.10.15
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
   dns-server 71.243.0.12 68.237.161.12 65.106.1.196 65.106.7.196
   netbios-name-server 10.10.10.2
ip domain name REMOVED
ip name-server 65.106.1.196
ip name-server 65.106.7.196
ip name-server 71.243.0.12
ip name-server 68.237.161.12
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic timeout 300
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 3600 min 3600
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
voice class h323 1
  call start slow
voice class cause-code 1
no-circuit
voice register global
max-dn 160
max-pool 40
voice hunt-group 1 parallel
final 299
list 121,125,147,169
timeout 60
pilot 511
voice hunt-group 2 parallel
final 511
list 134,145,163,167,168
timeout 16
pilot 512
voice hunt-group 3 parallel
final 6511
list 120,151
timeout 29
pilot 513
voice hunt-group 4 parallel
final 6146
list 133,146
timeout 29
pilot 514
voice hunt-group 5 sequential
final 511
list 129,135
timeout 29
pilot 515
voice source-group CCA_SIP_SOURCE_GROUP
access-list 2
translation-profile incoming SIP_Incoming
voice translation-rule 6
rule 1 /7183320545/ /298/
voice translation-rule 7
rule 1 /7183326800/ /298/
voice translation-rule 9
rule 1 /7186488491/ /123/
voice translation-rule 15
rule 1 /7187430820/ /180/
voice translation-rule 410
rule 1 /^9\(.......)\)$/ /171\1/
rule 2 /^9\(.*\)/ /\1/
rule 15 /^...$/ /7183326800/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 15 /.*/ /7183326800/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^81\(...\)/ /\1/
rule 2 /^81\(....\)/ /\1/
voice translation-rule 1114
rule 1 /\(^...$\)/ /81\1/
rule 2 /\(^....$\)/ /81\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile 7183320545-AA_Called_6
translate called 6
voice translation-profile 7183326800-AA_Called_7
translate called 7
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile DrPrivate_Called_15
translate called 15
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile RobertaPrivate_Called_9
translate called 9
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile multisiteInbound
translate called 1113
voice translation-profile multisiteOutbound
translate calling 1114
voice translation-profile nondialable
translate called 1000
voice-card 0
application
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
  param number-of-hunt-grps 10
  param queue-len 30
  param queue-cme-debugs 1
  param aa-hunt1 A295
license udi pid UC520-32U-8FXO-K9 sn FTX132180BX
archive
log config
  logging enable
  logging size 600
  hidekeys
username admin privilege 15 secret 5 REMOVED
username vpn secret 5 REMOVED
username pingerID password 0 REMOVED
ip tftp source-interface Loopback0
track 1 ip sla 1 reachability
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
group 2
crypto isakmp key REMOVED address 0.0.0.0 0.0.0.0
crypto isakmp identity hostname
crypto isakmp client configuration group EZVPN_GROUP_1
key REMOVED
wins 10.10.10.2
pool SDM_POOL_1
acl SPLIT-TUNNEL
save-password
include-local-lan
max-users 5
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec df-bit clear
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
crypto map multisite 1 ipsec-isakmp
description 57ST
set peer REMOVED
set peer REMOVED
match address MULTISITE
qos pre-classify
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 100 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address REMOVED 255.255.255.248
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip policy route-map director
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
description Verizon FIOS on Vlan10
switchport access vlan 10
interface FastEthernet0/1/7
description Barracuda Web Filter
interface FastEthernet0/1/8
description Server 10.10.10.2
switchport mode trunk
macro description cisco-switch
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
ip mtu 1300
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip access-group 101 in
ip nat inside
h323-gateway voip bind srcaddr 10.10.10.1
interface Vlan2
ip address 10.7.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip tcp adjust-mss 1380
interface Vlan10
ip address REMOVED 255.255.255.0
ip access-group 105 in
ip nat outside
interface Vlan100
ip address 10.1.1.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip local pool SDM_POOL_1 10.10.10.250 10.10.10.254
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source route-map FIOS interface Vlan10 overload
ip nat inside source route-map VPN_RMAP interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 REMOVED track 1
ip route 0.0.0.0 0.0.0.0 REMOVED 10
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip route 150.2.0.0 255.255.0.0 10.10.10.10
ip route 207.155.153.0 255.255.255.0 FastEthernet0/0 REMOVED
ip access-list extended FIOS-ROUTE-MAP
deny   ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
deny   ip 10.10.10.0 0.0.0.255 10.7.2.0 0.0.0.255
deny   ip 10.7.1.0 0.0.0.255 10.10.20.0 0.0.0.255
deny   ip 10.7.1.0 0.0.0.255 10.7.2.0 0.0.0.255
deny   ip any 207.155.153.0 0.0.0.255
permit ip 10.10.10.0 0.0.0.255 any
permit ip 10.7.1.0 0.0.0.255 any
ip access-list extended ISP1
permit ip 207.155.153.0 0.0.0.255 any
ip access-list extended ISP2
ip access-list extended MULTISITE
permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip 10.7.1.0 0.0.0.255 10.10.20.0 0.0.0.255
permit ip 10.10.10.0 0.0.0.255 10.7.2.0 0.0.0.255
permit ip 10.7.1.0 0.0.0.255 10.7.2.0 0.0.0.255
ip access-list extended ROUTE-MAP
ip access-list extended SPLIT-TUNNEL
permit ip 10.10.20.0 0.0.0.255 any
permit ip 10.7.2.0 0.0.0.255 any
permit ip 10.1.1.0 0.0.0.255 any
permit ip 10.1.10.0 0.0.0.3 any
ip sla 1
icmp-echo 4.2.2.2
threshold 300
timeout 300
frequency 3
ip sla schedule 1 life forever start-time now
logging esm config
logging trap debugging
logging 10.10.10.3
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit 10.7.1.0 0.0.0.255
access-list 2 permit 10.10.10.1
access-list 2 permit 10.10.20.1
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 207.155.153.31
access-list 2 permit 10.10.10.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 deny   any
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 100 remark SDM_ACL Category=1
access-list 100 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 100 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 100 deny   ip 10.7.1.0 0.0.0.255 any
access-list 100 deny   ip 10.10.10.0 0.0.0.255 any
access-list 100 deny   ip REMOVED 0.0.0.7 any
access-list 100 deny   ip REMOVED 0.0.0.255 any
access-list 100 deny   ip 10.1.1.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny   ip 10.1.10.0 0.0.0.3 any
access-list 101 deny   ip 10.7.1.0 0.0.0.255 any
access-list 101 deny   ip REMOVED 0.0.0.7 any
access-list 101 deny   ip REMOVED 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.7.1.0 0.0.0.255 any
access-list 102 deny   ip 10.10.10.0 0.0.0.255 any
access-list 102 deny   ip REMOVED 0.0.0.7 any
access-list 102 deny   ip REMOVED 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 10.10.10.0 0.0.0.255 any
access-list 103 deny   ip REMOVED 0.0.0.7 any
access-list 103 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip REMOVED 0.0.0.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_35##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit ahp any host REMOVED
access-list 104 permit esp any host REMOVED
access-list 104 permit udp any host REMOVED eq isakmp
access-list 104 permit udp any host REMOVED eq non500-isakmp
access-list 104 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 104 permit ip 10.7.2.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 104 permit ip 10.10.20.0 0.0.0.255 10.7.1.0 0.0.0.255
access-list 104 permit ip 10.7.2.0 0.0.0.255 10.7.1.0 0.0.0.255
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.7.1.0 0.0.0.255 any
access-list 104 deny   ip 10.10.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp host 65.106.1.196 eq domain any
access-list 104 permit udp host 65.106.7.196 eq domain any
access-list 104 permit icmp any host REMOVED echo-reply
access-list 104 permit icmp any host REMOVED time-exceeded
access-list 104 permit icmp any host REMOVED unreachable
access-list 104 permit udp host 207.155.153.31 eq 5060 any
access-list 104 permit udp host 207.155.153.31 any eq 5060
access-list 104 permit udp host 10.10.20.1 eq 5060 any
access-list 104 permit udp host 10.10.20.1 any eq 5060
access-list 104 permit udp host 10.10.10.1 eq 5060 any
access-list 104 permit udp host 10.10.10.1 any eq 5060
access-list 104 permit udp any any range 16384 32767
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip host 0.0.0.0 any
access-list 104 deny   ip any any
access-list 105 remark FIOS BACKUP INBOUND ACL
access-list 105 permit ahp any any
access-list 105 permit esp any any
access-list 105 permit udp any any eq isakmp
access-list 105 permit udp any any eq non500-isakmp
access-list 105 permit ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 105 permit ip 10.7.2.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 105 permit ip 10.10.20.0 0.0.0.255 10.7.1.0 0.0.0.255
access-list 105 permit ip 10.7.2.0 0.0.0.255 10.7.1.0 0.0.0.255
access-list 105 deny   ip 10.1.10.0 0.0.0.3 any
access-list 105 deny   ip 10.7.1.0 0.0.0.255 any
access-list 105 deny   ip 10.10.10.0 0.0.0.255 any
access-list 105 deny   ip 10.1.1.0 0.0.0.255 any
access-list 105 permit udp host 71.243.0.12 eq domain any
access-list 105 permit udp host 68.237.161.12 eq domain any
access-list 105 permit icmp any any echo-reply
access-list 105 permit icmp any any time-exceeded
access-list 105 permit icmp any any unreachable
access-list 105 permit udp host 10.10.20.1 eq 5060 any
access-list 105 permit udp host 10.10.20.1 any eq 5060
access-list 105 permit udp host 10.10.10.1 eq 5060 any
access-list 105 permit udp host 10.10.10.1 any eq 5060
access-list 105 permit udp any any range 16384 32767
access-list 105 deny   ip 10.0.0.0 0.255.255.255 any
access-list 105 deny   ip 172.16.0.0 0.15.255.255 any
access-list 105 deny   ip 192.168.0.0 0.0.255.255 any
access-list 105 deny   ip 127.0.0.0 0.255.255.255 any
access-list 105 deny   ip host 255.255.255.255 any
access-list 105 deny   ip host 0.0.0.0 any
access-list 105 deny   ip any any
route-map director permit 8
match ip address ISP1
set ip next-hop REMOVED
route-map director permit 9
match ip address ISP2
route-map FIOS permit 1
match ip address FIOS-ROUTE-MAP
match interface Vlan10
route-map VPN_RMAP permit 1
match ip address ROUTE-MAP
match interface FastEthernet0/0
snmp-server community public RO
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-6.bin alias spa50x-30x-7-4-6.bin
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7925/APPSH-1.3.4SR1.SBN alias APPSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.4SR1.LOADS alias CP7925G-1.3.4SR1.LOADS
tftp-server flash:/phones/7925/GUIH-1.3.4SR1.SBN alias GUIH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/MISCH-1.3.4SR1.SBN alias MISCH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.4SR1.SBN alias SYSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.4SR1.SBN alias TNUXH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.4SR1.SBN alias WLANH-1.3.4SR1.SBN
tftp-server flash:/phones/7945_7965/apps45.8-5-4TH1-6.sbn alias apps45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-4TH1-6.sbn alias cnu45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-4TH1-6.sbn alias cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-4TH1-6.sbn alias dsp45.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-4TH1-6.sbn alias jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-4S.loads alias SCCP45.8-5-4S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/Desktops/320x212x12/List.xml alias Desktops/320x212x12/List.xml
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/phones/7931/apps31.8-5-4TH1-6.sbn alias apps31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-4TH1-6.sbn alias cnu31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-4TH1-6.sbn alias cvm31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-4TH1-6.sbn alias dsp31.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-4TH1-6.sbn alias jar31sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-4S.loads alias SCCP31.8-5-4S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
control-plane
voice-port 0/0/0
  station-id number 301
caller-id enable
voice-port 0/0/1
station-id number 302
caller-id enable
voice-port 0/0/2
station-id number 303
caller-id enable
voice-port 0/0/3
station-id number 304
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 299
description Configured by CCA 4 FXO-0/1/0-AA-Custom-AA-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-AA-Custom-AA-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-AA-Custom-AA-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-AA-Custom-AA-OP
caller-id enable
voice-port 0/3/0
description Configured by CCA 4 FXO-0/3/0-AA-Custom-AA-OP
caller-id enable
voice-port 0/3/1
description Configured by CCA 4 FXO-0/3/1-AA-Custom-AA-OP
caller-id enable
voice-port 0/3/2
description Configured by CCA 4 FXO-0/3/2-AA-Custom-AA-OP
caller-id enable
voice-port 0/3/3
description Configured by CCA 4 FXO-0/3/3-AA-Custom-AA-OP
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
  member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 301
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 302
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 303
  port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 304
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 150 pots
port 0/3/0
dial-peer voice 151 pots
port 0/3/1
dial-peer voice 152 pots
port 0/3/2
dial-peer voice 153 pots
port 0/3/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
  destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 154 pots
destination-pattern A4
port 0/3/0
no sip-register
dial-peer voice 155 pots
destination-pattern A5
port 0/3/1
no sip-register
dial-peer voice 156 pots
destination-pattern A6
port 0/3/2
no sip-register
dial-peer voice 157 pots
destination-pattern A7
port 0/3/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 299
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
  no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 297
b2bua
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American*7-Digit Local**
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
description **CCA*North American*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
  no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 2100 voip
corlist incoming call-internal
description **CCA*INTERSITE inbound call to AVE-X
translation-profile incoming multisiteInbound
incoming called-number 81[1-9]..
voice-class h323 1
dtmf-relay h245-alphanumeric
codec g711ulaw
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to 57ST
translation-profile outgoing multisiteOutbound
destination-pattern 82[1-9]..
session target ipv4:10.10.20.1
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
dial-peer voice 2102 voip
description **CCA*INTERSITE inbound call to AVE-X - INTERCOM
incoming called-number 810...
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
dial-peer voice 2103 voip
description **CCA*INTERSITE outbound calls to 57ST - INTERCOM
destination-pattern 820...
voice-class h323 1
codec g711ulaw
fax protocol cisco
  no vad
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (XO Communications) **
session target sip-server
incoming called-number .%
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk (XO Communications) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1021 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1022 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1023 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1024 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1025 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1026 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1027 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1028 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1029 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1030 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3011 voip
description DrPrivate
translation-profile incoming DrPrivate_Called_15
incoming called-number 7187430820
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
destination-pattern 298
b2bua
dtmf-relay rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 3002 voip
description 7183320545-AA
translation-profile incoming 7183320545-AA_Called_6
incoming called-number 7183320545
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3005 voip
description RobertaPrivate
translation-profile incoming RobertaPrivate_Called_9
incoming called-number 7186488491
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
direct-inward-dial
dial-peer voice 3003 voip
description 7183326800-AA
translation-profile incoming 7183326800-AA_Called_7
incoming called-number 7183326800
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
no dial-peer outbound status-check pots
presence
sccp blf-speed-dial retry-interval 70 limit 20
presence call-list
max-subscription 160
watcher all
allow subscribe
sip-ua
retry invite 2
retry register 10
  timers connect 100
registrar ipv4:207.155.153.31:5060 expires 3600
sip-server ipv4:207.155.153.31:5060
host-registrar
presence enable
telephony-service
video
em logout 0:0 0:0 0:0
fxo hook-flash
max-ephones 40
max-dn 160
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Radiology Associates
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-4S
load 7945 SCCP45.8-5-4S
load 7965 SCCP45.8-5-4S
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-6
load 502G spa50x-30x-7-4-6
load 504G spa50x-30x-7-4-6
load 508G spa50x-30x-7-4-6
load 509G spa50x-30x-7-4-6
load 301 spa50x-30x-7-4-6
load 303 spa50x-30x-7-4-6
time-zone 12
voicemail 299
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 REMOVED
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
  night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
night-service date Apr 5 00:00 23:59
night-service date Apr 6 00:00 23:59
night-service date May 19 00:00 23:59
night-service date May 20 00:00 23:59
night-service date Sep 6 00:00 23:59
night-service date Sep 9 00:00 23:59
night-service date Sep 10 00:00 23:59
night-service date Sep 30 00:00 23:59
night-service date Oct 1 00:00 23:59
night-service date Nov 25 00:00 23:59
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  15
softkeys remote-in-use  Newcall
softkeys idle  Redial Dnd Cfwdall Pickup Gpickup Newcall Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Park Endcall Trnsfer TrnsfVM Confrn Acct Hold
button-layout 7931 2
ephone-template  16
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
ephone-template  17
softkeys remote-in-use  CBarge Newcall
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
ephone-template  18
ephone-dn  1
number 101 no-reg primary
description System Page
name IP-Paging1
paging ip 239.1.1.1 port 2000
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 127 no-reg primary
label 127
description Angela Kreynin
name Angela Kreynin
call-forward busy 299
call-forward noan 299 timeout 30
ephone-dn  11  dual-line
number 146 no-reg primary
label 146
description Mary Sullivan
name Mary Sullivan
ephone-dn  12  dual-line
number 126 no-reg primary
label 126
description Myra Soto
name Myra Soto
ephone-dn  13  dual-line
number 123 secondary 7186488491 no-reg primary
label 123
description Roberta Sickles
name Roberta Sickles
ephone-dn  14  dual-line
number 167 no-reg primary
label 167
description Daniel Norowitz
name Daniel Norowitz
ephone-dn  15  dual-line
number 134 no-reg primary
label 134
description Harvey Coopersmith
name Harvey Coopersmith
ephone-dn  16  dual-line
number 199 no-reg primary
label 199
description Domenick Landriscina
name Domenick Landriscina
ephone-dn  17  dual-line
number 147 no-reg primary
label 147
description Iryna Sytina
name Iryna Sytina
call-forward noan 299 timeout 45
ephone-dn  18  dual-line
number 133 no-reg primary
label 133
description Maritza Ferrer
name Maritza Ferrer
ephone-dn  19  dual-line
number 180 secondary 7187430820 no-reg primary
label 180
description Doctor Private Line
name Doctor Private Line
call-forward busy 511
call-forward noan 511 timeout 30
ephone-dn  20  dual-line
number 164 no-reg primary
label 164
description Nuclear Medicine
name Nuclear Medicine
ephone-dn  21  dual-line
number 144 no-reg primary
label 144
description Roz Zelman
name Roz Zelman
ephone-dn  22  dual-line
number 150 no-reg primary
label 150
description Patient Phone
name Patient Phone
ephone-dn  23  dual-line
number 136 no-reg primary
label 136
description Back Office
name Back Office
ephone-dn  24  dual-line
number 132 no-reg primary
label 132
description XRAY Room
name XRAY Room
corlist incoming user-internal
ephone-dn  25  dual-line
number 128 no-reg primary
label 128
description Sonography I
name Sonography I
ephone-dn  26  dual-line
number 135 no-reg primary
label 135
description Johanna Fernandez
name Johanna Fernandez
ephone-dn  27  dual-line
number 170 no-reg primary
label 170
description Lunchroom Phone
name Lunchroom Phone
ephone-dn  28  dual-line
number 131 no-reg primary
label 131
description Bone Density
name Bone Density
ephone-dn  29  dual-line
number 124 no-reg primary
label 124
description Mammo Room
name Mammo Room
ephone-dn  30  dual-line
number 145 no-reg primary
label 145
description PET Reading
name PET Reading
ephone-dn  31
number 181
label 181
name Doctor Incoming
call-forward busy 182
ephone-dn  32
number 182
label 182
call-forward busy 183
ephone-dn  33
number 183
label 183
call-forward busy 184
ephone-dn  34
number 184
label 184
call-forward noan 511 timeout 60
ephone-dn  35  dual-line
number 121 no-reg primary
label 121
description Jillian Resciniti
name Jillian Resciniti
ephone-dn  36  dual-line
number 125 no-reg primary
  label 125
description Diana Bolbirer
name Diana Bolbirer
call-forward busy 187
ephone-dn  37  dual-line
number 169 no-reg primary
label 169
description Kathy Didik
name Kathy Didik
call-forward busy 188
ephone-dn  38  dual-line
number 120 no-reg primary
label 120
description Nina Kukushkina
name Nina Kukushkina
ephone-dn  39  dual-line
number 129 no-reg primary
label 129
description Philippe Zamor
name Philippe Zamor
ephone-dn  40  dual-line
number 163 no-reg primary
label 163
description Mammo Reading
name Mammo Reading
ephone-dn  41  dual-line
number 151 no-reg primary
label 151
description Paulina Revich
name Paulina Revich
ephone-dn  42  dual-line
number 122 no-reg primary
label 122
description CT Room
name CT Room
ephone-dn  43  dual-line
number 165 no-reg primary
label 165
description File Room
name File Room
ephone-dn  44  dual-line
number 161 no-reg primary
label 161
description MRI Room
name MRI Room
ephone-dn  45  dual-line
number 130 no-reg primary
label 130
description PET CT
name PET CT
ephone-dn  46  dual-line
number 160 no-reg primary
label 160
description Sonography II
name Sonography II
ephone-dn  47  dual-line
number 168 no-reg primary
label 168
description Steven Winter
name Steven Winter
ephone-dn  48  dual-line
number 190 no-reg primary
label 190
description Wireless Phone
name Wireless Phone
call-forward noan 299 timeout 20
ephone-dn  50
number 185
label 185
name Patient Incoming
  call-forward busy 186
ephone-dn  51
number 186
label 186
ephone-dn  52
number 187
label 187
ephone-dn  53
number 188
label 188
ephone-dn  54  dual-line
number 171
label 171
description Kitchen Phone
name Kitchen Phone
ephone-dn  55  dual-line
number 172
label 172
description Downstars Filing
name Downstars Filing
ephone-dn  56  dual-line
number 173
label 173
description Downstairs FilingII
name Downstairs FilingII
ephone-dn  100
number 0127 no-reg primary
label Intercom
description Intercom Angela K
name Intercom
intercom 0 no-mute
ephone-dn  101
number 0146 no-reg primary
label Intercom
description Intercom Mary Sullivan
name Intercom
intercom 0 no-mute
ephone-dn  102
number 0126 no-reg primary
label Intercom
description Intercom Myra M
name Intercom
intercom 0 no-mute
ephone-dn  103
number 0123 no-reg primary
label Intercom
description Intercom Roberta Sickles
name Intercom
intercom 0 no-mute
ephone-dn  104
number 0167 no-reg primary
label Intercom
description Intercom Daniel Norowitz
name Intercom
intercom 0 no-mute
ephone-dn  105
number 0134 no-reg primary
label Intercom
description Intercom Harvey Coopersmith
name Intercom
intercom 0 no-mute
ephone-dn  106
number 0147 no-reg primary
label Intercom
description Intercom Iryna Sytina
name Intercom
intercom 0 no-mute
ephone-dn  107
number 0136 no-reg primary
label Intercom
description Intercom Back Office
name Intercom
intercom 0 no-mute
ephone-dn  108
number 0164 no-reg primary
label Intercom
description Intercom Nuclear Medicine
name Intercom
intercom 0 no-mute
ephone-dn  109
number 0132 no-reg primary
label Intercom
description Intercom XRAY Room
name Intercom
intercom 0 no-mute
ephone-dn  110
number 0128 no-reg primary
label Intercom
description Intercom Sonography I
name Intercom
intercom 0 no-mute
ephone-dn  111
number 0131 no-reg primary
label Intercom
description Intercom Bone Density
name Intercom
intercom 0 no-mute
ephone-dn  112
number 0124 no-reg primary
label Intercom
description Intercom Mammo Room
name Intercom
intercom 0 no-mute
ephone-dn  113
number 0121 no-reg primary
label Intercom
description Intercom Jillian Resciniti
name Intercom
intercom 0 no-mute
ephone-dn  114
number 0125 no-reg primary
label Intercom
description Intercom Diana Bolbirer
name Intercom
intercom 0 no-mute
ephone-dn  115
number 0169 no-reg primary
label Intercom
description Intercom Kathy Didik
name Intercom
intercom 0 no-mute
ephone-dn  116
number 0120 no-reg primary
label Intercom
description Intercom Nina Kukushkina
name Intercom
intercom 0 no-mute
ephone-dn  117
number 0129 no-reg primary
label Intercom
description Intercom Zamor Philippe
name Intercom
intercom 0 no-mute
ephone-dn  118
number 0163 no-reg primary
label Intercom
description Intercom Mammo Reading
name Intercom
intercom 0 no-mute
ephone-dn  119
number 0151 no-reg primary
label Intercom
description Intercom Paulina Revich
name Intercom
intercom 0 no-mute
ephone-dn  120
number 0122 no-reg primary
label Intercom
description Intercom CT Room
name Intercom
intercom 0 no-mute
ephone-dn  121
number 0165 no-reg primary
label Intercom
description Intercom File Room
name Intercom
intercom 0 no-mute
ephone-dn  122
number 0161 no-reg primary
label Intercom
description Intercom MRI Room
name Intercom
intercom 0 no-mute
ephone-dn  123
number 0130 no-reg primary
label Intercom
description Intercom PET CT
name Intercom
intercom 0 no-mute
ephone-dn  124
number 0160 no-reg primary
label Intercom
description Intercom Sonography II
name Intercom
intercom 0 no-mute
ephone-dn  125
number 0168 no-reg primary
label Intercom
description Intercom Steven Winter
name Intercom
intercom 0 no-mute
ephone-dn  126
number 0144 no-reg primary
label Intercom
description Intercom Roz Zelman
name Intercom
intercom 0 no-mute
ephone-dn  127
number 0170 no-reg primary
label Intercom
description Intercom Lunchroom
name Intercom
intercom 0 no-mute
ephone-dn  128
number 0145 no-reg primary
label Intercom
description Intercom PET Reading
name Intercom
intercom 0 no-mute
ephone-dn  129
number 0133 no-reg primary
label Intercom
description Intercom Maritza Ferrer
name Intercom
intercom 0 no-mute
call-forward all 701
ephone-dn  130
number 0135 no-reg primary
label Intercom
description Intercom Johnanna Fernandez
name Intercom
intercom 0 no-mute
ephone-dn  149
number 7183326800
description SIP Main Number registration
preference 10
ephone-dn  150
number 708 no-reg primary
park-slot timeout 45 limit 2 transfer 511
label Park Slot 708
allow watch
ephone-dn  151
number 707 no-reg primary
label Park Slot 707
allow watch
ephone-dn  152
number 706 no-reg primary
label Park Slot 706
allow watch
ephone-dn  153
number 705 no-reg primary
label Park Slot 705
allow watch
ephone-dn  154
number 704 no-reg primary
label Park Slot 704
  allow watch
ephone-dn  155
number 703 no-reg primary
label Park Slot 703
allow watch
ephone-dn  156
number 702 no-reg primary
label Park Slot 702
allow watch
ephone-dn  157
number 701 no-reg primary
label Park Slot 701
allow watch
ephone-dn  158
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 299
ephone-dn  159
number A801... no-reg primary
mwi off
ephone-dn  160
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
video
mac-address 0025.4594.49AC
ephone-template 15
max-calls-per-button 2
username "Myra" password 12345
speed-dial 1 820 label "Intercom BP"
speed-dial 2 82 label "Call BP"
speed-dial 3 101 label "Page"
paging-dn 1
type 7931
button  1:12 2:102 3m157 4m156
button  5m155 6m154 7m153 8m152
button  9m151 10m150
ephone  2
video
mac-address 0025.4594.4A8E
ephone-template 15
username "AngelaK" password 123445
paging-dn 1
type 7931
button  1:10 2:100 3m157 4m156
button  9m151 10m150
ephone  3
video
mac-address 0021.70BF.2843
ephone-template 16
username "DomenickLandriscina" password 12345
speed-dial 1 0 label "Intercom"
mtp
type CIPC
button  1:16
ephone  4
video
mac-address 0025.84A2.38FC
ephone-template 15
username "MarySullivan" password 12345
paging-dn 1
type 7931
button  1:11 2:101 3m157 4m156
button  9m151 10m150
ephone  5
video
mac-address 0025.4594.49A9
ephone-template 15
username "DanielNorowitz" password 12345
blf-speed-dial 1 701 label "Park Slot 701"
blf-speed-dial 2 702 label "Park Slot 702"
blf-speed-dial 3 703 label "Park Slot 703"
blf-speed-dial 4 704 label "Park Slot 704"
blf-speed-dial 5 705 label "Park Slot 705"
blf-speed-dial 6 706 label "Park Slot 706"
blf-speed-dial 7 707 label "Park Slot 707"
blf-speed-dial 8 708 label "Park Slot 708"
blf-speed-dial 9 820 label "Intercom BP"
blf-speed-dial 10 82 label "Call BP"
blf-speed-dial 11 101 label "Page"
blf-speed-dial 12 91718 label "9-1-718"
paging-dn 1
type 7931
button  1:14 2:104 3:19
ephone  6
video
mac-address 0025.84A2.3A43
ephone-template 15
username "RobertaSickles" password 12345
paging-dn 1
type 7931
button  1:13 2:103 3m157 4m156
button  9m151 10m150
ephone  7
video
mac-address 0025.4594.495A
ephone-template 16
username "HarveyCoopersmith" password 12345
paging-dn 1
type 7931
button  1:15 2:105 3:19
ephone  8
video
mac-address 0027.0DBD.3FB9
ephone-template 15
username "PaulinaRevich" password 12345
paging-dn 1
type 7931
button  1:41 2:119 3m157 4m156
button  9m151 10m150
ephone  9
video
mac-address 0027.0DC0.16A7
ephone-template 15
username "NinaKukushkina" password 12345
paging-dn 1
type 7931
button  1:38 2:116 3m157 4m156
button  9m151 10m150
ephone  10
video
mac-address 0027.0DBE.5FBB
ephone-template 15
username "JillianResciniti" password 12345
paging-dn 1
type 7931
button  1:35 2:113 3o50,51,52,53 4o31,32,33,34
ephone  11
video
mac-address 0027.0DBD.3DB8
ephone-template 15
username "BackOffice" password 12345
paging-dn 1
type 7931
button  1:23 2:107 3:19
ephone  12
video
mac-address 0027.0DC0.1889
ephone-template 15
username "KathyDidik" password 12345
paging-dn 1
type 7931
  button  1:37 2:115 3o50,51,52,53 4o31,32,33,34
ephone  13
video
mac-address 0027.0DC0.16AE
ephone-template 15
username "IrynaSytina" password 12345
paging-dn 1
type 7931
button  1:17 2:106 3o50,51,52,53 4o31,32,33,34
ephone  14
video
mac-address 0027.0DBE.5F7F
ephone-template 15
username "StevenWinter" password 12345
paging-dn 1
type 7931
button  1:47 2:125 3:19
ephone  15
video
  mac-address 0025.84A1.03F8
ephone-template 16
username "PatientPhone" password 12345
paging-dn 1
type 7945
button  1:22
ephone  16
video
mac-address 0027.0DBE.5FEE
ephone-template 15
username "Sono2" password 12345
paging-dn 1
type 7931
button  1:46 2:124 3m157 4m156
button  9m151 10m150
ephone  17
video
mac-address 0027.0DC0.182B
ephone-template 15
username "MammoRoom" password 12345
paging-dn 1
type 7931
button  1:29 2:112 3m157 4m156
button  9m151 10m150
ephone  18
video
mac-address 0027.0DC0.16A3
ephone-template 15
username "NuclearMedicine" password 12345
paging-dn 1
  type 7931
button  1:20 2:108 3m157 4m156
button  9m151 10m150
ephone  19
video
mac-address 0025.84A2.3D47
ephone-template 15
username "CTRoom" password 12345
paging-dn 1
type 7931
button  1:42 2:120 3m157 4m156
button  9m151 10m150
ephone  20
video
mac-address 0027.0DC0.175D
ephone-template 15
username "PhilippeZamor" password 12345
paging-dn 1
type 7931
button  1:39 2:117 3m157 4m156
button  9m151 10m150
ephone  21
video
mac-address 0025.84A2.3AEE
ephone-template 15
username "PetCTRoom" password 12345
paging-dn 1
type 7931
button  1:45 2:123 3m157 4m156
button  9m151 10m150
ephone  22
video
mac-address 0025.84A2.3C80
ephone-template 15
username "FileRoom" password 12345
paging-dn 1
type 7931
button  1:43 2:121 3m157 4m156
button  9m151 10m150
ephone  23
video
mac-address 0027.0DC0.188C
ephone-template 15
username "MRIRoom" password 12345
paging-dn 1
type 7931
button  1:44 2:122 3m157 4m156
button  9m151 10m150
ephone  24
video
mac-address 0025.84A2.384F
ephone-template 15
username "MammoReading" password 12345
paging-dn 1
type 7931
button  1:40 2:118 3:19
ephone  25
video
mac-address 0027.0DC0.180E
ephone-template 15
username "DianaBolbirer" password 12345
paging-dn 1
type 7931
button  1:36 2:114 3o50,51,52,53 4o31,32,33,34
ephone  26
video
mac-address 0027.0DC0.1709
ephone-template 15
username "BoneDensity" password 12345
paging-dn 1
type 7931
button  1:28 2:111 3m157 4m156
button  9m151 10m150
ephone  27
video
mac-address 0025.84A2.384B
  ephone-template 15
username "JohannaFernandez" password 12345
paging-dn 1
type 7931
button  1:26 2:130 3m157 4m156
button  9m151 10m150
ephone  28
video
mac-address 0025.84A2.37B4
ephone-template 15
username "MaritzaFerrer" password 12345
paging-dn 1
type 7931
button  1:18 2:129 3m157 4m156
button  9m151 10m150
ephone  29
video
mac-address 0027.0DBE.5FEB
ephone-template 15
username "Sono1" password 12345
paging-dn 1
type 7931
button  1:25 2:110 3m157 4m156
button  9m151 10m150
ephone  30
video
mac-address 0025.84A2.3849
ephone-template 15
  username "XrayRoom" password 12345
paging-dn 1
type 7931
button  1:24 2:109
ephone  31
video
mac-address 0025.84A2.3DAD
ephone-template 15
username "RozZelman" password 12345
paging-dn 1
type 7931
button  1:21 2:126 3m157 4m156
button  9m151 10m150
ephone  32
video
mac-address 0025.84A2.38C8
ephone-template 15
username "Lunchroom" password 12345
paging-dn 1
type 7931
button  1:27 2:127 3m157 4m156
button  9m151 10m150
ephone  33
  video
mac-address 0025.84A2.3E89
ephone-template 15
username "PetReading" password 12345
paging-dn 1
type 7931
button  1:30 2:128 3:19
ephone  34
mac-address 0023.3341.81D3
max-calls-per-button 4
username "WirelessPhone" password 12345
speed-dial 1 101 label "Page"
speed-dial 2 70 label "Park"
speed-dial 3 82 label "Call BP"
speed-dial 4 0 label "Intercom"
type 7925
button  1:48 2:13
ephone  35
mac-address 0026.998D.3A71
username "Kitchen" password 12345
paging-dn 1
type 504G
button  1:54
ephone  36
mac-address 0002.FDFF.3548
username "Downstairs" password 12345
paging-dn 1
  type 504G
button  1:55
ephone  37
mac-address 8843.E157.F458
username "DownstairsFilingII" password 12345
paging-dn 1
type 504G
button  1:56
ephone-hunt 50 longest-idle
pilot A295
list 121, 125, 147, 169
timeout 15, 15, 15, 15
no-reg pilot
statistics collect
description *** CCA BACD ***
ephone-hunt 51 sequential
no-reg pilot
statistics collect
ephone-hunt 52 sequential
no-reg pilot
statistics collect
ephone-hunt 53 sequential
no-reg pilot
statistics collect
ephone-hunt 54 sequential
no-reg pilot
statistics collect
ephone-hunt 55 sequential
no-reg pilot
statistics collect
ephone-hunt 56 sequential
  no-reg pilot
statistics collect
ephone-hunt 57 sequential
no-reg pilot
statistics collect
ephone-hunt 58 sequential
no-reg pilot
statistics collect
ephone-hunt 59 sequential
no-reg pilot
statistics collect
alias exec cca_voice_mode PBX
banner login ^CCisco Configuration Assistant. Version: 3.0 (1). Fri Apr 08 13:34:56 EDT 2011^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
event manager session cli username "pingerID"
event manager applet vpn-pinger
event timer watchdog time 120 maxrun 100
action 1.0 cli command "enable"
action 2.0 cli command "ping ip 10.10.20.1 source VLAN1 repeat 2 timeout 5"
end
AVE-X#
Site B
version 15.1
no service pad
service internal
hostname 57ST
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2
boot-end-marker
aaa new-model
crypto pki trustpoint TP-self-signed-3718070020
subject-name cn=IOS-Self-Signed-Certificate-3718070020
rsakeypair TP-self-signed-3718070020
crypto pki certificate chain TP-self-signed-3718070020
  3082024A 308201B3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33373138 30373030 3230301E 170D3039 31303038 30333139
  34385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 37313830
  37303032 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100ABA4 0F2C92FC 16372835 8ACDA90C CDD57D61 69D88B50 D080AA59 C19D32EF
  EAA3D7A4 6945FD85 F2FBB20B B8F811DC 76BB9064 9DB84BF1 67D15C24 8D1A5FD6
  01229253 7B8EB50D 12C104B5 54076109 62B90AF8 6D8608C1 9F98020A 4EB544AC
  F8C35AD0 ADFB9977 7F97599F 7DDFC9F0 A5CF88D8 87539FD2 345FFF3B 22C177DE
6BD70203 010001A3 72307030 0F060355 1D130101 FF040530 030101FF 301D0603
  551D1104 16301482 12353753 542E3635 2E34342E 3234352E 32323630 1F060355
  1D230418 30168014 1262803D 5B8C0238 0D6DF0AC ABF19832 A6697398 301D0603
  551D0E04 16041412 62803D5B 8C02380D 6DF0ACAB F19832A6 69739830 0D06092A
  864886F7 0D010104 05000381 81006308 641709B9 21FE9FD5 4451CB2B 45D58726
  EAE6A0DC B0B27B49 999DBF0C BBFC7A3A A426735D F9B14940 29F79DCB 28CF1177
  0730CC82 0C3A90AE D863569B 3D177927 DE04B8CA 3D600EF6 5E19992C 6CFACFAF
  D95F4C56 C1014DCB 58976420 7B641E1E 63F9C30E A06AA14D 6F000D32 095DEAE8
  7CD8501B B478673E 0AD6B0F7 F403
   quit
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.10.20.1 10.10.20.9
ip dhcp excluded-address 10.10.20.241 10.10.20.255
ip dhcp pool phone
ip dhcp pool data
   import all
   network 10.10.20.0 255.255.255.0
   default-router 10.10.20.1
   dns-server 208.67.222.222 208.67.220.220 167.206.112.138 167.206.7.4 65.106.1.196 65.106.7.196
ip domain name RA.NET
ip name-server 167.206.112.138
ip name-server 167.206.7.4
ip name-server 208.67.222.222
ip name-server 208.67.220.220
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
voice class h323 1
  call start slow
no-circuit
max-dn 128
max-pool 32
final 299
list 220,221,231,232
timeout 60
pilot 511
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
rule 1 /2147856461/ /298/
voice translation-rule 12
rule 1 /7184366855/ /226/
voice translation-rule 19
rule 1 /7184366755/ /298/
rule 1 /7184377482/ /298/
voice translation-rule 21
rule 1 /7184367337/ /298/
rule 1 /7184366747/ /298/
rule 1 /^9\(.......)\)$/ /718\1/
rule 15 /^...$/ /7184367337/
rule 1 /.*/ //
rule 15 /.*/ /7184367337/
rule 1 /^9/ //
rule 1 /^82\(...\)/ /\1/
rule 2 /^82\(....\)/ /\1/
rule 1 /\(^...$\)/ /82\1/
rule 2 /\(^....$\)/ /82\1/
rule 1 /^6/ //
voice translation-profile 2147856461-AA_Called_4
translate calling 3265
translate called 4
voice translation-profile 7184366747-AA_Called_22
translate called 22
voice translation-profile 7184366755-AA_Called_19
translate called 19
voice translation-profile 7184367337-AA_Called_21
translate called 21
voice translation-profile 7184377482-AA_Called_20
translate called 20
voice translation-profile DrZelmanDID_Called_12
translate called 12
voice-card 0
application
  param queue-len 30
  param aa-hunt1 A295
license udi pid UC520-24U-8FXO-K9 sn FTX1331819P
archive
log config
  logging enable
  logging size 600
  hidekeys
encr 3des
group 2
encr 3des
group 2
key REMOVED
wins 10.10.10.2
pool SDM_POOL_1
acl SPLIT-TUNNEL
save-password
include-local-lan
max-users 5
   virtual-template 1
description AVE-X
set peer REMOVED
set peer REMOVED
qos pre-classify
interface Loopback0
ip nat inside
ip nat outside
duplex auto
speed auto
ip nat inside
switchport access vlan 2
no cdp enable
description Optimum Online on Vlan10
ip unnumbered Vlan1
ip mtu 1300
interface Vlan1
ip address 10.10.20.1 255.255.255.0
ip nat inside
h323-gateway voip bind srcaddr 10.10.20.1
interface Vlan2
ip address 10.7.2.1 255.255.255.0
ip nat inside
interface Vlan10
ip access-group 106 in
ip nat outside
interface Vlan100
ip nat inside
ip local pool SDM_POOL_1 10.10.20.250 10.10.20.254
ip http server
ip http path flash:
ip nat inside source route-map OPTIMUM interface Vlan10 overload
remark Specify Traffic allowed to go to XO Communications
remark Specify Traffic allowed to go to Optimum Online
ip access-list extended OPTIMUM-ROUTE-MAP
deny   ip 10.7.2.0 0.0.0.255 10.7.1.0 0.0.0.255
deny   ip 10.7.2.0 0.0.0.255 10.10.10.0 0.0.0.255
deny   ip 10.10.20.0 0.0.0.255 10.7.1.0 0.0.0.255
deny   ip 10.10.20.0 0.0.0.255 10.10.10.0 0.0.0.255
ip sla 1
icmp-echo 4.2.2.2
threshold 300
timeout 300
frequency 3
logging esm config
logging source-interface Vlan1
logging 10.10.10.3
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 1 permit 10.7.2.0 0.0.0.255
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 permit 10.10.20.0 0.0.0.255
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 208.93.224.230
access-list 3 deny   any
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.7.2.0 0.0.0.255 any
access-list 101 deny   ip 10.10.20.0 0.0.0.255 any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 102 deny   ip 10.7.2.0 0.0.0.255 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.7.2.0 0.0.0.255 any
access-list 103 deny   ip 10.10.20.0 0.0.0.255 any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 104 deny   ip 10.10.20.0 0.0.0.255 any
access-list 104 deny   ip REMOVED 0.0.0.7 any
access-list 104 permit ip any any
access-list 105 remark XO Communications INBOUND ACL
access-list 105 permit ahp any host REMOVED
access-list 105 permit esp any host REMOVED
access-list 105 permit udp any host REMOVED eq isakmp
access-list 105 permit udp any host REMOVED eq non500-isakmp
access-list 105 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 105 permit ip 10.7.1.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 105 permit ip 10.10.10.0 0.0.0.255 10.7.2.0 0.0.0.255
access-list 105 permit ip 10.7.1.0 0.0.0.255 10.7.2.0 0.0.0.255
access-list 105 deny   ip 10.7.2.0 0.0.0.255 any
access-list 105 deny   ip 10.10.20.0 0.0.0.255 any
access-list 105 permit udp host 65.106.1.196 eq domain any
access-list 105 permit udp host 65.106.7.196 eq domain any
access-list 105 permit icmp any host REMOVED echo-reply
access-list 105 permit icmp any host REMOVED time-exceeded
access-list 105 permit icmp any host REMOVED unreachable
access-list 106 remark OPTIMUM BACKUP ACL
access-list 106 permit ahp any any
access-list 106 permit esp any any
access-list 106 permit udp any any eq isakmp
access-list 106 permit udp any any eq non500-isakmp
access-list 106 permit ip 10.10.10.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 106 permit ip 10.7.1.0 0.0.0.255 10.10.20.0 0.0.0.255
access-list 106 permit ip 10.10.10.0 0.0.0.255 10.7.2.0 0.0.0.255
access-list 106 permit ip 10.7.1.0 0.0.0.255 10.7.2.0 0.0.0.255
access-list 106 deny   ip 10.1.10.0 0.0.0.3 any
access-list 106 deny   ip 10.7.2.0 0.0.0.255 any
access-list 106 deny   ip 10.10.20.0 0.0.0.255 any
access-list 106 deny   ip 10.1.1.0 0.0.0.255 any
access-list 106 permit udp host 167.206.112.138 eq domain any
access-list 106 permit udp host 167.206.7.4 eq domain any
access-list 106 permit udp host 208.67.222.222 eq domain any
access-list 106 permit udp host 208.67.220.220 eq domain any
access-list 106 permit icmp any any echo-reply
access-list 106 permit icmp any any time-exceeded
access-list 106 permit icmp any any unreachable
access-list 106 permit udp host 208.93.224.230 eq 5060 any
access-list 106 permit udp host 208.93.224.230 any eq 5060
access-list 106 permit ip 208.93.0.0 0.0.0.255 any
access-list 106 permit udp host 10.10.20.1 eq 5060 any
access-list 106 permit udp host 10.10.20.1 any eq 5060
access-list 106 permit udp host 10.10.10.1 eq 5060 any
access-list 106 permit udp host 10.10.10.1 any eq 5060
access-list 106 permit udp any any range 16384 32767
access-list 106 deny   ip 10.0.0.0 0.255.255.255 any
access-list 106 deny   ip 172.16.0.0 0.15.255.255 any
access-list 106 deny   ip 192.168.0.0 0.0.255.255 any
access-list 106 deny   ip 127.0.0.0 0.255.255.255 any
access-list 106 deny   ip host 255.255.255.255 any
access-list 106 deny   ip host 0.0.0.0 any
access-list 106 deny   ip any any
route-map OPTIMUM permit 1
match ip address OPTIMUM-ROUTE-MAP
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
tftp-server term71.default.loads
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server flash:APPS-1.0.4.SBN
tftp-server flash:GUI-1.0.4.SBN
tftp-server flash:SYS-1.0.4.SBN
tftp-server flash:TNUX-1.0.4.SBN
tftp-server flash:TNUXR-1.0.4.SBN
tftp-server flash:WLAN-1.0.4.SBN
tftp-server flash:apps37sccp.1-1-1-1.bin
tftp-server flash:spa525g-7-1-3.bin
tftp-server flash:/phones/521_524/cp524g-8-1-16b.bin alias cp524g-8-1-16b.bin
tftp-server flash:/phones/7921/GUI-1.2.1.SBN alias GUI-1.2.1.SBN
tftp-server flash:/phones/7921/TNUX-1.2.1.SBN alias TNUX-1.2.1.SBN
tftp-server flash:/phones/7921/SYS-1.2.1.SBN alias SYS-1.2.1.SBN
tftp-server flash:/phones/7921/APPS-1.2.1.SBN alias APPS-1.2.1.SBN
tftp-server flash:/phones/7921/CP7921G-1.2.1.LOADS alias CP7921G-1.2.1.LOADS
tftp-server flash:/phones/7921/WLAN-1.2.1.SBN alias WLAN-1.2.1.SBN
tftp-server flash:/phones/7921/TNUXR-1.2.1.SBN alias TNUXR-1.2.1.SBN
tftp-server flash:/phones/7914/S00105000300.sbn alias S00105000300.sbn
tftp-server flash:/phones/7925/GUIH-1.3.1.SBN alias GUIH-1.3.1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.1.SBN alias TNUXH-1.3.1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.1.LOADS alias CP7925G-1.3.1.LOADS
tftp-server flash:/phones/7925/APPSH-1.3.1.SBN alias APPSH-1.3.1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.1.SBN alias WLANH-1.3.1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.1.SBN alias SYSH-1.3.1.SBN
tftp-server flash:Desktops/CampusNight.png
tftp-server flash:Desktops/CiscoFountain.png
tftp-server flash:Desktops/CiscoLogo.png
tftp-server flash:Desktops/Fountain.png
tftp-server flash:Desktops/MorroRock.png
tftp-server flash:Desktops/NantucketFlowers.png
tftp-server flash:Desktops/TN-CampusNight.png
tftp-server flash:Desktops/TN-CiscoFountain.png
tftp-server flash:Desktops/TN-CiscoLogo.png
tftp-server flash:Desktops/TN-Fountain.png
tftp-server flash:Desktops/TN-MorroRock.png
tftp-server flash:Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:autoattendant/AA_SBCS_v01.aef
tftp-server flash:autoattendant/AA_SBCS_v02.aef
tftp-server flash:autoattendant/AA_transfer.aef
tftp-server flash:bacdprompts/app-b-acd-2.1.2.3.tcl
tftp-server flash:bacdprompts/app-b-acd-aa-2.1.2.3.tcl
tftp-server flash:bacdprompts/en_bacd_allagentsbusy.au
tftp-server flash:bacdprompts/en_bacd_disconnect.au
tftp-server flash:bacdprompts/en_bacd_enter_dest.au
tftp-server flash:bacdprompts/en_bacd_invalidoption.au
tftp-server flash:bacdprompts/en_bacd_music_on_hold.au
tftp-server flash:bacdprompts/en_bacd_options_menu.au
tftp-server flash:bacdprompts/en_bacd_welcome.au
tftp-server flash:bacdprompts/en_bacd_xferto_operator.au
tftp-server flash:cca/Key_Phoneloads.csv
tftp-server flash:cca/sccpphoneloadstable.csv
tftp-server flash:cca/UC500_CCA_Dir_7.0.3.txt
tftp-server flash:gui/admin_user.html
tftp-server flash:gui/admin_user.js
tftp-server flash:gui/CiscoLogo.gif
tftp-server flash:gui/CME_GUI_README.TXT
tftp-server flash:gui/Delete.gif
tftp-server flash:gui/dom.js
tftp-server flash:gui/downarrow.gif
tftp-server flash:gui/ephone_admin.html
tftp-server flash:gui/logohome.gif
tftp-server flash:gui/normal_user.html
tftp-server flash:gui/normal_user.js
tftp-server flash:gui/Plus.gif
tftp-server flash:gui/sxiconad.gif
tftp-server flash:gui/Tab.gif
tftp-server flash:gui/telephony_service.html
tftp-server flash:gui/uparrow.gif
tftp-server flash:gui/xml-test.html
tftp-server flash:gui/xml.template
tftp-server flash:gui/sn/handshake.html
tftp-server flash:gui/sn/handshake.swf
tftp-server flash:media/music-on-hold.au
tftp-server flash:media/music-on-hold_10db.au
tftp-server flash:ringtones/Analog1.raw
tftp-server flash:ringtones/Analog2.raw
tftp-server flash:ringtones/AreYouThere.raw
tftp-server flash:ringtones/AreYouThereF.raw
tftp-server flash:ringtones/Bass.raw
tftp-server flash:ringtones/CallBack.raw
tftp-server flash:ringtones/Chime.raw
tftp-server flash:ringtones/Classic1.raw
tftp-server flash:ringtones/Classic2.raw
tftp-server flash:ringtones/ClockShop.raw
tftp-server flash:ringtones/DistinctiveRingList.xml
tftp-server flash:ringtones/Drums1.raw
tftp-server flash:ringtones/Drums2.raw
tftp-server flash:ringtones/FilmScore.raw
tftp-server flash:ringtones/HarpSynth.raw
tftp-server flash:ringtones/Jamaica.raw
tftp-server flash:ringtones/KotoEffect.raw
tftp-server flash:ringtones/MusicBox.raw
tftp-server flash:ringtones/Piano1.raw
tftp-server flash:ringtones/Piano2.raw
tftp-server flash:ringtones/Pop.raw
tftp-server flash:ringtones/Pulse1.raw
tftp-server flash:ringtones/Ring1.raw
tftp-server flash:ringtones/Ring2.raw
tftp-server flash:ringtones/Ring3.raw
tftp-server flash:ringtones/Ring4.raw
tftp-server flash:ringtones/Ring5.raw
tftp-server flash:ringtones/Ring6.raw
tftp-server flash:ringtones/Ring7.raw
tftp-server flash:ringtones/RingList.xml
tftp-server flash:ringtones/Sax1.raw
tftp-server flash:ringtones/Sax2.raw
tftp-server flash:ringtones/Vibe.raw
tftp-server flash:vlan.dat
tftp-server flash:/phones/7975/apps75.8-4-1-23.sbn alias apps75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cnu75.8-4-1-23.sbn alias cnu75.8-4-1-23.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-4-1-23.sbn alias cvm75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/dsp75.8-4-1-23.sbn alias dsp75.8-4-1-23.sbn
tftp-server flash:/phones/7975/jar75sccp.8-4-1-23.sbn alias jar75sccp.8-4-1-23.sbn
tftp-server flash:/phones/7975/SCCP75.8-4-2S.loads alias SCCP75.8-4-2S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-4-1-23.sbn alias apps70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-4-1-23.sbn alias cnu70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-4-1-23.sbn alias cvm70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-4-1-23.sbn alias dsp70.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-4-1-23.sbn alias jar70sccp.8-4-1-23.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-4-2S.loads alias SCCP70.8-4-2S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-4-1-23.sbn alias apps45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-4-1-23.sbn alias cnu45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-4-1-23.sbn alias cvm45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-4-1-23.sbn alias dsp45.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-4-1-23.sbn alias jar45sccp.8-4-1-23.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-4-2S.loads alias SCCP45.8-4-2S.loads
tftp-server flash:/phones/7942_7962/apps42.8-4-1-23.sbn alias apps42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-4-1-23.sbn alias cnu42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-4-1-23.sbn alias cvm42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-4-1-23.sbn alias dsp42.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-4-1-23.sbn alias jar42sccp.8-4-1-23.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-4-2S.loads alias SCCP42.8-4-2S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7941_7961/apps41.8-4-1-23.sbn alias apps41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-4-1-23.sbn alias cnu41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-4-1-23.sbn alias cvm41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-4-1-23.sbn alias dsp41.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-4-1-23.sbn alias jar41sccp.8-4-1-23.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-4-2S.loads alias SCCP41.8-4-2S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7940_7960/P00308001000.bin alias P00308001000.bin
tftp-server flash:/phones/7940_7960/P00308001000.loads alias P00308001000.loads
tftp-server flash:/phones/7940_7960/P00308001000.sb2 alias P00308001000.sb2
tftp-server flash:/phones/7940_7960/P00308001000.sbn alias P00308001000.sbn
tftp-server flash:/phones/7937/apps37sccp.1-3-2-0.bin alias apps37sccp.1-3-2-0.bin
tftp-server flash:/phones/7936/cmterm_7936.3-3-16-0.bin alias cmterm_7936.3-3-16-0.bin
tftp-server flash:/phones/7916/B016-1-0-3.SBN alias B016-1-0-3.SBN
tftp-server flash:/phones/7915/B015-1-0-3.SBN alias B015-1-0-3.SBN
tftp-server flash:/phones/525/spa525g-7-1-9.bin alias spa525g-7-1-9.bin
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
connection plar opx 298
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
voice-port 0/3/0
caller-id enable
voice-port 0/3/1
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
sccp
sccp ccm group 1
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member emergency
member internal
member local
member emergency
member toll-free
member internal
member local
member local-plus
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
port 0/0/0
no sip-register
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
port 0/3/0
port 0/3/1
port 0/3/2
port 0/3/3
port 0/1/0
no sip-register
port 0/1/1
no sip-register
port 0/1/2
no sip-register
port 0/1/3
no sip-register
port 0/3/0
no sip-register
port 0/3/1
no sip-register
port 0/3/2
no sip-register
port 0/3/3
no sip-register
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
description **CCA*INTERSITE inbound call to 57ST
incoming called-number 82[1-9]..
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
description **CCA*INTERSITE outbound calls to AVE-X
destination-pattern 81[1-9]..
session target ipv4:10.10.10.1
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
description **CCA*INTERSITE inbound call to 57ST - INTERCOM
incoming called-number 820...
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
description **CCA*INTERSITE outbound calls to AVE-X - INTERCOM
destination-pattern 810...
voice-class h323 1
codec g711ulaw
fax protocol cisco
no vad
dial-peer voice 3008 voip
description DrZelmanDID
translation-profile incoming DrZelmanDID_Called_12
incoming called-number 7184366855
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3015 voip
description 7184366755-AA
translation-profile incoming 7184366755-AA_Called_19
incoming called-number 7184366755
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3016 voip
description 7184377482-AA
translation-profile incoming 7184377482-AA_Called_20
incoming called-number 7184377482
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3017 voip
description 7184367337-AA
translation-profile incoming 7184367337-AA_Called_21
incoming called-number 7184367337
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 3018 voip
description 7184366747-AA
translation-profile incoming 7184366747-AA_Called_22
incoming called-number 7184366747
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 2013 voip
permission term
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
description ** Passthrough Inbound Calls for PSTN from CUE **
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^...$
dtmf-relay rtp-nte
codec g711ulaw
no vad
direct-inward-dial
dial-peer voice 3000 voip
description 2147856461-AA
translation-profile incoming 2147856461-AA_Called_4
incoming called-number 2147856461
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
sip-ua
retry invite 2
retry register 10
timers connect 100
registrar ipv4:208.93.224.230:5060 expires 3600
sip-server ipv4:208.93.224.230:5060
host-registrar
telephony-service
video
max-ephones 32
max-dn 128
max-redirect 20
system message RadiologyAssociates
cnf-file perphone
load 7914 S00105000300
load 7915-12 B015-1-0-3
load 7915-24 B015-1-0-3
load 7916-12 B016-1-0-3
load 7916-24 B016-1-0-3
load 7921 CP7921G-1.2.1
load 7925 CP7925G-1.3.1
load 7936 cmterm_7936.3-3-16-0
load 7937 apps37sccp.1-3-2-0
load 7960-7940 P00308001000
load 7941 SCCP41.8-4-2S
load 7941GE SCCP41.8-4-2S
load 7942 SCCP42.8-4-2S
load 7945 SCCP45.8-4-2S
load 7961 SCCP41.8-4-2S
load 7961GE SCCP41.8-4-2S
load 7962 SCCP42.8-4-2S
load 7965 SCCP45.8-4-2S
load 7970 SCCP70.8-4-2S
load 7971 SCCP70.8-4-2S
load 7975 SCCP75.8-4-2S
load 521G-524G cp524g-8-1-16b
load 525G spa525g-7-1-9
time-zone 12
voicemail 299
moh flash:/media/music-on-hold_10db.au
dn-webedit
time-webedit
transfer-pattern .T
night-service date Nov 26 00:00 23:59
create cnf-files version-stamp 7960 Aug 03 2011 18:46:54
ephone-template  15
ephone-template  16
ephone-template  17
ephone-template  18
ephone-dn  1
description Paging
name IP-Paging1
ephone-dn  9
description MoH
moh out-call ABC
number 201 no-reg primary
label 201
description 201
huntstop channel
number 202 no-reg primary
label 202
description 202
name 202
number 232 no-reg primary
label 232
description Paola Polanco
name Paola Polanco
number 231 no-reg primary
label 231
description Jennifer Baldwin
name Jennifer Baldwin
number 205 no-reg primary
label 205
description 205
name 205
number 229 no-reg both
label 229
name Mammo Room
number 207 no-reg primary
label 207
description 207
name 207
number 208 no-reg primary
label 208
description 208
name 208
number 209 no-reg primary
label 209
description 209
name 209
number 210 no-reg primary
label 210
description 210
name 210
number 211 no-reg primary
label 211
description 211
name 211
number 212 no-reg primary
label 212
description 212
name 212
number 213 no-reg primary
label 213
description 213
name 213
number 214 no-reg primary
label 214
description 214
name 214
number 215 no-reg primary
label 215
description 215
name 215
number 216 no-reg primary
label 216
description 216
name 216
number 217 no-reg primary
label 217
description 217
name 217
number 218 no-reg primary
label 218
description 218
name 218
number 219 no-reg primary
label 219
description 219
name 219
number 220 no-reg primary
label 220
description Maria Matos
name Maria Matos
number 221 no-reg both
label 221
description Jeandebra Rosales
name Jeandebra Rosales
ephone-dn  31  dual-line
number 222 no-reg primary
label 222
description Carla Muccillo
name Carla Muccillo
ephone-dn  32  dual-line
number 223 no-reg both
label 223
name Bone Density
ephone-dn  33  dual-line
number 224 no-reg primary
label 224
name XRAY Room
ephone-dn  34  dual-line
number 225 no-reg primary
label 225
description 225
name 225
number 226 secondary 7184366855 no-reg primary
label 226
description Allen Zelman
name Allen Zelman
number 227 no-reg both
label 227
description CT Room
name CT Room
number 228 no-reg primary
label 228
description Ultrasound Room
name Ultrasound Room
ephone-dn  100
number 0220 no-reg primary
label Intercom
description Maria Matos Intercom
name Intercom
intercom 0 no-mute
ephone-dn  101
number 0221 no-reg primary
label Intercom
description Jean Rosales Intercom
name Intercom
intercom 0 no-mute
ephone-dn  102
number 0222 no-reg primary
label Intercom
name Intercom
intercom 0 no-mute
ephone-dn  103
number 0223 no-reg primary
label Intercom
description Bone Density Intercom
name Intercom
intercom 0 no-mute
ephone-dn  104
number 0224 no-reg primary
label Intercom
description XRAY Room Intercom
name Intercom
intercom 0 no-mute
ephone-dn  105
number 0225 no-reg primary
label Intercom
name Intercom
intercom 0 no-mute
ephone-dn  106
number 0226 no-reg primary
label Intercom
description Allen Zelman Intercom
name Intercom
intercom 0 no-mute
ephone-dn  107
number 0227 no-reg primary
label Intercom
description CT Room Intercom
name Intercom
intercom 0 no-mute
ephone-dn  108
number 0228 no-reg primary
label Intercom
description Ultrasound Room Intercom
name Intercom
intercom 0 no-mute
ephone-dn  109
number 0229 no-reg primary
label Intercom
description Mammo Room Intercom
name Intercom
intercom 0 no-mute
ephone-dn  110
number 0230 no-reg primary
label Intercom
name Intercom
intercom 0 no-mute
ephone-dn  111
number 0231 no-reg primary
label Intercom
description Jennifer Baldwin Intercom
name Intercom
intercom 0 no-mute
ephone-dn  112
number 0232 no-reg primary
label Intercom
description Paola Polanco Intercom
name Intercom
intercom 0 no-mute
ephone-dn  117
label Park Slot 708
ephone-dn  118
label Park Slot 707
ephone-dn  119
label Park Slot 706
ephone-dn  120
label Park Slot 705
ephone-dn  121
label Park Slot 704
ephone-dn  122
label Park Slot 703
ephone-dn  123
label Park Slot 702
ephone-dn  124
label Park Slot 701
ephone-dn  125
number 7184367337
preference 10
ephone-dn  126
ephone-dn  127
mwi off
ephone-dn  128
mwi on
ephone  1
video
mac-address 0021.70B8.4EF2
ephone-template 16
mtp
type CIPC
button  1:10 2w35
ephone  2
video
mac-address 0025.84A2.36B6
ephone-template 15
username "JeanRosales" password 12345
speed-dial 2 81 label "Call Ave X"
speed-dial 3 810 label "Intercom Ave X"
paging-dn 1
type 7931
button  1:30 2m124 3m123 4m122
button  5m121 6m120 7m119 8m118
button  9m117 16w35 17:101
ephone  3
video
mac-address 0025.84A2.3AF3
ephone-template 15
username "MariaMatos" password 12345
paging-dn 1
type 7931
button  1:29 2m124 3m123 4m122
button  9m117 16w35 17:100
ephone  4
video
mac-address 0025.84A2.39F8
ephone-template 15
username "PaolaPolanco" password 12345
paging-dn 1
type 7931
button  1:12 2m124 3m123 4m122
button  9m117 16w35 17:112
ephone  5
video
mac-address 0025.84A2.3B1D
ephone-template 15
username "JenniferBaldwin" password 12345
paging-dn 1
type 7931
button  1:13 2m124 3m123 4m122
button  9m117 16w35 17:111
ephone  6
video
mac-address 0025.84A2.3BCD
ephone-template 15
username "AllenZelman" password 12345
speed-dial 2 91718 label "1-718"
speed-dial 3 81 label "Call Ave X"
speed-dial 4 810 label "Intercom Ave X"
paging-dn 1
type 7931
button  1:35 2m124 3m123 4m122
button  9m117 16:106
ephone  7
video
mac-address 0025.84A2.3B18
ephone-template 15
username "CarlaMuccillo" password 12345
paging-dn 1
type 7931
button  1:31 2m124 3m123 4m122
button  9m117 16w35 17:102
ephone  8
video
mac-address 0025.84A2.39FC
ephone-template 15
username "XRay" password 12345
paging-dn 1
type 7931
button  1:33 2m124 3m123 4m122
button  9m117 16w35 17:104
ephone  9
video
mac-address 0025.84A2.36B9
ephone-template 15
username "Ultrasound" password 12345
paging-dn 1
type 7931
button  1:37 2m124 3m123 4m122
button  9m117 16w35 17:108
ephone  10
video
mac-address 0025.84A2.3AF0
ephone-template 15
paging-dn 1
type 7931
button  1:32 2m124 3m123 4m122
button  9m117 16w35 17:103
ephone  11
video
mac-address 0025.84A2.3B37
ephone-template 15
username "Mammo" password 12345
paging-dn 1
type 7931
button  1:15 2m124 3m123 4m122
button  9m117 16w35 17:109
ephone  12
video
mac-address 0025.4594.4C7E
ephone-template 15
username "CT" password 12345
paging-dn 1
type 7931
button  1:36 2m124 3m123 4m122
button  9m117 16w35 17:107
ephone  13
mac-address 0016.EAC3.E1B8
type CIPC
button  1:11
ephone-hunt 50 sequential
pilot A295
list 231
timeout 10
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
no-reg pilot
statistics collect
banner login ^CCisco Configuration Assistant. Version: 3.0 (1). Thu Mar 10 15:33:54 EST 2011^C
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
ntp server pool.ntp.org prefer
action 2.0 cli command "ping ip 10.10.10.1 source VLAN1 repeat 2 timeout 5"
end
57ST#
Thanks for everything
Also side not - if i disable supplementary sip refer - the keystrokes to the auto attendant from the outside disconnect the call as soon as it connects.
Hi There,
IN regards to the the VM and AA no longer responding to DTMF codes, please go at THIS thread and follow the instructions, this will resolve the issue for you and is a directly related issue to upgrading to 8.2
As for your site-2-site calling, I am a little stumped on this one, your config looks to be good and CCA built it right.
Can you tell me what are the edge routers on both sites? I.E what controls the Internet and what type of Internet connection are you using?
Also can you confirm that you have enabled Call Controll in CCA as well and that QoS is enabled??
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I think the problem has to be due to this CCA 3.1 bug - the supplementary sip refer needs to be on for the audio to work between sides... but when it is on the transfers dont work right.. maybe after i switch all the dmtf codes to the rte setting.. i can turn sip refer back on and the audio will come through.
there are no edge routers just standard verizon fios boxes going directly to the wan port.. the uc520 is the edge device on both sides.
Let us know how you go once you have made the change... Since the UC is the concentrator all should be good.
Cheers,
David.
