03-09-2009 01:51 PM - edited 03-21-2019 12:58 AM
Trying to deploy a UC520.
Having problems with XO SIP service.
Need to upgrade system to 4.2.5
Currently changed the default ip to 192.168.16.19 to fit it their network scheme.
Have had no problems until I did the software upgarde. Current version was 4.2.0.
Now when I try to access the system thru CCA it says unreachable.
I have also tried the default IP 192.168.10.1
Still nothing!
How do I get my access back to the box?
03-09-2009 02:12 PM
If it is running DHCP, you could see where the responce is coming from. If not, you would have to log in via the console port.
This link will give you information on the cabling to log in.
https://www.cisco.com/en/US/products/hw/routers/ps332/products_tech_note09186a0080094ce6.shtml
Use the 800 series router as an example.
After you connect, it will ask for username and password. First try what you have configured last. If that fails, try cisco/cisco.
Then type this.
show ip int bri
You should see an IP address there that you can connect to.
Steven
03-09-2009 03:50 PM
yeah I turned off DHCP for their internal server.
Will give a try. Strange just took away the ip interface.
Phones still can call internally, but no access to CME.
