09-18-2018 07:12 AM
is there any possibility how to use LDAPS or LDAP over TLS with SPA5xx or 88xx phones?
The only method I can use is a digest MD5.
But I need to secure also data in LDAP session (not only credentials).
I'm using the latest FW.
Best regards,
Jakub Zima
Solved! Go to Solution.
11-06-2018 12:36 AM
thanks for the reply.
I just found that in the latest FW there is finally possible to use LDAPs for 88xx series.
LDAPs is also available for 68xx.
The only trouble which I found is that Cisco signed certificate is needed on LDAP server.
CSR can be signed here: https://webapps.cisco.com/software/edos/home#
11-03-2018 12:11 PM
Its not possible as far as I know.
Pokud jsem neco zasadniho neprehledl ...
