License for 16 IP phone support on SPA9000
artemkozlov
Hello!
In datasheet on cisco.com I see that SPA9000 initially supports 4 SIP-compatible IP phones and is upgradable to 16 IP phones with an easy-to-install license key upgrade. Partnumber for license upgrade is SPA9000UPG. But I don't see this position in price list.
Is this license still actual?
or may be it is not required now
Thank you
2 Accepted Solutions
icastrov
indeed, the license is not needed any longer. Please upgrade the SPA9000 to the latest/greatest release available in cisco.com and you'll have the 16 IP Phones supported by default ;-)
Thanks!
-nacho
This change was done in firmware 5.2.5. I'm attaching the release notes for your reference.
Thanks!
-nacho
icastrov
Thanks!
-nacho
Thank you for reply!
Is this information present somewhere on www.cisco.com?
Where can I read about it?
Do you have any link?
Thanks!
-nacho
