Linksys 3102 VoIP Gateway Question
ethersurfer
I recently bought a 3102 box and since I have several PAP2's configured and working great - I had no problem configuring the PSTN line - so when I dial my Sipgate number I get the PSTN dialtone. I did not change anything in the 3102's factory defaults and it works fine for about 30 minutes. Then what happens is that the PSTN drops so when i dial in, it just rings the SIP number until i get the sip provider's "no one answering" message.
If I boot the 3102 - the problem goes away for another 30 minutes - then comes back.
I could not find any reference to this issue in forums or docs.
Would very much appreciate someone's help.
Thanks Ethersurfer
What is the firmware version running on your SPA? Can you add the config and a trace during problem?
Regards.
