Loses the web access of a CP-7821 3PCC
Hi there,
I loose the web GUI access to a CP-7821 3PCC, I just reset it but all I can get is:
Before the reset I was able to access the WebGUI but the credentials won't able to let me in.
Thanks for help.
Guillaume
ADAM CRISP
Level 4
Level 4
I used to see that quite a lot, but not so much now on later versions.
Try using a different browser - MSEdge seems to work surprisingly well when FF and Chrome do the above..
Adam
Can't really use MSEdge as we don't use MS Windows here, but Chromium for Linux Mint do the job well. Thx!
Had a chance to use MSEdge and it is not working either.
Guillaume
Is there another solution that I can try?
Thank-you!
Guillaume
