12-01-2010 01:02 PM - edited 03-21-2019 03:19 AM
Does anyone know why some of my softkeys are missing from our SPA50X model phones. For example my Park softkey is missing even though that service has been applied to that phone. The WEB UI on the phone under Connected Softkeys shows that "Park" should be listed. Also
Supplementary Services are enabled .
We are running Broadsoft version 17 with SPA504G and 509G
Solved! Go to Solution.
12-10-2010 03:23 PM
Hi robray_sc,
Verify that the phones:
- are running 7.4.6
- have softkeys enabled: Phone tab > Programmable Softkeys > Programmable Softkey Enable: Yes
- have no syntax errors in the softkey config
Programmable softkeys and softkeys only appear in a phone state that they are supported in. In other words, you will not see park when the phone is not in the connected state.
What may be confusing is the "park" and "unpark" predefined softkeys in phone's web-UI tab. You cannot use these definitions for Broadsoft, they only work with Cisco-based call control such as the SPA9000.
Here's how you can get park/unpark working:
1. Remove Regional tab > Vertical Service Activation Codes so they don't confuse the issue.
2. Verify that your phones have call park capabilities on Broadsoft, sounds like you've already done this.
3. To park a call: press hold, dial *68, press # to park against your extension number
4. To unpark, dial *86.
Note: if you don't perform step 1, the phone will attempt to resolve the dialed Feature Access Code (FAC) as a local star (*) code which is *not* what you want.
Patrick
12-10-2010 03:23 PM
Hi robray_sc,
- are running 7.4.6
Patrick
12-17-2010 11:14 AM
Thanks Patrick-
Thats crazy that Park doesn't show up while on a connected call but other softkeys too (Conf., xfer, redial, etc..).
However using the feature codes for park *68 and unpark *88 do work.
We also have sccp phones (7940s and 7960s) registered to Broadworks and they show the Park and ParkRtv softkeys.
12-17-2010 12:59 PM
Hi rabray_sc,
Thanks for the honest feedback, it's appreciated.
I'm forwarding your comments to our product team.
Patrick
You only need one reference document for all SPA phone firmware, information, and utilities.
