01-28-2014 01:48 PM - edited 03-21-2019 08:02 AM
Hi, our current outgoing translation rules for our PRI look as follows -
voice translation-rule 85
rule 1 /842/ /40778XXXX/
rule 2 /835/ /40747XXXX/
rule 3 /836/ /407472XXXX/
rule 4 /837/ /407472XXXX/
rule 5 /838/ /407781XXXX/
rule 6 /839/ /407781XXXX/
rule 7 /840/ /407781XXXX/
rule 8 /841/ /407781XXXX/
rule 10 /843/ /407781XXXX/
rule 11 /881/ /407373XXXX/
rule 12 /880/ /407373XXXX/
rule 13 /882/ /407373XXXX/
rule 14 /^8\(..\)$/ /4074XXXX\1/
rule 15 /^...$/ /407472XXXX/
voice translation-profile PROFILE_ALL_T1E1
translate calling 85
CCA only allows 15 outgoing translation rules. I've read that we can add more than 15 rules via the cli ... should I add another voice translation rule (86) , then add it under the
voice translation-profile PROFILE_ALL_T1E1 along with the current 85? Or what is best way to accomplish this?
Current s/w versions:
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)
System image file is "flash:/uc500-advipservicesk9-mz.151-2.T2"
01-28-2014 06:01 PM
Hi Chris,
Try to update software to version 15.1(4)M5.
I have more rules per voice translation-rule here (up to 100).
01-29-2014 09:26 AM
Thanks, I'll look into that upgrade.
