Multi incoming calls (spa 525g - 5 lines)
denague2209
I got a SPA 525G2 color with 5 lines.
I don't know how correctly configurate into (web browser IP panel of my phone) to use incoming calls with it's rule :
When line 1 is busy, i would like that next incoming calls goes to the 4 other lines empty.
Cause actually, all incoming calls goes to line 1. When i'm ever on phone into line 1 you imagine well that's it's not easy to manage.
Thanks for your help.
Denis
andreylozovoy
hello
here is the solution
private
private
private
In the Phone tab, under Miscellaneous Line Key Settings, you can
configure line mapping. Each LED (line/extension) can hold two calls. You can
assign an extension to two LEDs. The first call always causes the assigned LED to
flash. Choose one of the following:
• Vertical first—The next LED on the phone flashes with the second incoming
call.
• Horizontal first—The same LED to flashes with the second incoming call.
Vertical First
