Multi site UC500 series question
graeme
Level 4
Level 4
Hi Guys and girls,
I know this stuff is covered in the training and in the manuals but I am struggling to find the info I need and I am urgently finnishing off a proposal for a customer and would like to check a couple of things before I continue.
Proposal is a 3 site setup.
Site 1 UC560 + ESW520 48, and 24 port switchs and SRP 521 router
Sites 2 + 3 UC540 + ESW520 24port switches and SRP 521 Routers
Sites 2 and 3 connected via the SRP's VPN to Site 1.
Sites 1,2 + 3 with SIP trunks incoming and outgoing
The questions I have are as follows
1. Can we setup all systems to alk via the VPN so that Site 1 Phones extensions 100-199, Site 2 200-299, Site 3 300-399 and for example user on site 1 calls 203 and connects to user on site 2 all via IP via the VPN.
2. Can we have the incoming SIPs on all sites routed to the same reception operator in site 1?
3. Can we setup AA on Site one, and have i work for all calls?
4. can we setup AA  spereately per site.
5. Can we have user in Site 1 on extension 105, visit site 2 and have extension 105 available to him there?
Sorry for asking, but I know you guys will have the answers and its going to save me a lot of time, and maybe allow me to finnish this poropsal in time.
Thanks in advance
Graeme
Steven DiStefano
Multisite Design Requirements and Guidelines
Only the following network topologies are supported for individual customer sites that are members of a multisite deployment. Any of these site topologies can be combined as long as the total number of sites is 5 or fewer. The sites are configured with a full-mesh VPN — that is, every site has a direct link to every other site.
    • A single UC500 connected to the WAN.
    • A single SR520-T1 secure router combined with a UC500. The SR520-T1 is connected to the WAN and provides advanced security features, and the UC500 provides voice and data to the site. In this type of deployment, the data VLAN must be unique for both the SR520-T1 and the UC500.
    • For the current release, only the model SR520-T1 secure router is supported for use in Cisco SBCS multisite deployments configured using CCA.
IMPORTANT Each site must have a UC500 for voice and data. The Multisite Manager cannot be used to configure any of the following types of deployments:
  • A standalone SR520-T1 router as one of the sites
  • A data-only, site-to-site VPN between two or more SR500 secure routers
  • A remote phone behind an SR520-T1 without a UC500
This diagram shows a simple example of a deployment with two sites that illustrates the supported topologies and some of the design requirements discussed in this section.
The above example illustrates these key elements of multisite configuration:
  • Site topology. The Charlotte site provides an example of a site that has a UC500 behind an SR520-T1, while the San Jose site has a UC500 only.
  • Data VLAN IP addressing must be unique. Since the data VLAN IP addresses must be unique across all sites for any UC500 and also for any SR520-T1, the data VLAN IP for the UC500 at the Charlotte site is set to 192.168.10.1/24, and the data VLAN IP for the UC500 San Jose is set to 192.168.20.1/24. The VLAN IP for the SR520-T1 at the Charlotte site is 192.168.75.0/24, and there is no SR520-T1 present at the San Jose site (otherwise a unique data VLAN IP would also be required for it).
  • Dial plan and intersite dialing. For this configuration, we have chosen to use an intersite dialing prefix of "8." The Charlotte site ID is set to "1", and the San Jose site ID is set to 2. As shown in the example, phone users dial the IntersiteDialingPrefix + Site ID + extension to reach other sites. Both sites have their extension length set to 3. Although it is not required that sites use the same extension length, it is recommended for ease of use and configuration.
  • Static IP or DHCP WAN IP addressing is supported. The Charlotte site uses a static WAN IP address, while the San Jose site is configured to use DHCP. Since DHCP is used, Dynamic DNS (DDNS) is configured for the San Jose site.
  • Full-mesh VPN with authentication using pre-shared key. A global pre- shared key is configured identically for each site to provide authentication for the VPN tunnel.
  • Call admission control. Both sites are configured to allow a maximum of
    4 simultaneous calls over the WAN.
This table lists and describes multisite design requirements and guidelines in more details.
IMPORTANT Existing out-of-band configuration is not supported by the Multisite Manager. You must remove existing out-of-band multisite configuration before you can use the Multisite Manager.
Configuration Item
Requirements/Recommended Guidelines
Number of sites
Up to 5 sites in a full-mesh topology.
Number of IPsec tunnels
For UC520 and UC540 platforms, each customer site supports up to 10 IPsec tunnels. For UC560 platforms, each customer site supports up to 20 IPsec tunnels. This include EZVPN tunnels, SSL VPN tunnels, multisite VPN tunnels, and SPA525G phone VPN tunnels.
When a site is part of a multisite deployment,
N-1 of these VPN tunnels are used for the full-mesh site- to-site VPN, where N is the number of sites. For example, if the multisite deployment for a UC540 platform has 4 sites, 3 IPsec tunnels are used for the full-mesh site-to-site VPN, leaving 7 tunnels available for EZVPN and/or SSL VPN.
Firewall
Cisco Zone-Based Firewall (ZBF) on SR500 or Cisco IOS-based CBAC policy on the UC500. Third-party firewalls are not supported.
Data VLAN addressing
The data VLAN IP address for each UC500 and SR520- T1 must be unique across all sites.
If each site is at factory default, you must remember to modify the default data VLAN address during the initial configuration of each additional site member to ensure that it is unique. Use the Telephony Setup Wizard to configure the initial settings.
If one of the remote sites has an existing data VLAN IP address that is not unique, you must modify its data VLAN address. For a site that is not at factory default state, this can only be done through the Multisite Manager.
After modifying the data VLAN IP address, you will lose connectivity to the UC500, and must request and obtain a new IP address from the UC500. To do this, go to Start > Run on your PC and enter cmd to open a command prompt window. At the command prompt, enter the command ipconfig /renew.
WAN connection type
Sites can use either DHCP with DDNS configured or static IP addressing.
For sites that use DHCP to dynamically obtain an IP address, DDNS (Dynamic Domain Name Service) or some other DNS registration method must be used to manage dynamic addresses.
When configuring DDNS, the DDNS provider name, hostname for each site, and authentication information (username and password) must be provided as part of the multisite connection configuration. See Configuring DDNS.
The DDNS hostname must be unique for each site.
DDNS (Dynamic DNS) hosting service
DDNS must be configured for sites with DHCP WAN connections that are part of a multisite deployment. Sites that are configured with a static IP address are not required to configure DDNS.
These DDNS hosting services can be selected from the HTTP DDNS section in the Modify Internet Connection window (Configure > Routing > Internet Connection > Modify > Connection Settings).
  • cgi.tzo.com
  • dup.hn.org
  • members.dyndns.org
  • members.easydns.com
  • www.dynx.cx
  • www.justlinux.com
  • www.zoneedit.com
Accounts with these DDNS providers must be established outside of Configuration Assistant.
TIP Cisco recommends that you upgrade from the free package to a paid or premium package from the DDNS provider. For example, some free packages are designed to expire due to inactivity (for example, if the IP address is not updated in 30 days). Loss of the DNS support for a domain name means that the VPN tunnels can become inoperable or fail to come up, resulting in service interruptions.
Traffic Shaping/ Quality of Service (QoS)
Optional. Although this setting is optional, it is strongly recommended. Sites that have limited bandwidth should enable traffic shaping and configure QoS settings for multisite deployments.
Codec
You must choose either G.711 or G.729 as the codec to use for intersite calls. The G.729 codec offers higher compression, which can translate into significant bandwidth savings, but can result in poorer quality for some types of audio such as Music on Hold.
Call Admission Control
Optional. Configure Maximum Calls (maximum simultaneous calls) to ensure voice quality for intersite and VoIP calls by helping to prevent the Internet connection from being over-subscribed.
Configuration Assistant uses the currently configured QoS settings for upstream bandwidth, codec preference, and bandwidth reservation for voice media to provide recommendations for call admission control.
Dial Plan
Specify an Intersite Dialing Prefix for site-to-site calling.
To dial another site, phone users must dial:
Intersite Dialing Prefix + SiteID + Extension
This feature allows for flexibility in extension assignments for sites. Prefix digit that are already in use are not available for selection.
Extension length
It is recommended, but not required, that all sites in a multisite configuration use the same extension length.
Hostname
To avoid confusion when selecting the hostname from Configuration Assistant menus, it is recommended that you define system hostnames to be unique across all sites.
The system hostname is displayed in Configuration Assistant hostname selection menus and system prompts.
So after review of the above, which is from the CCA HELP, you can see the following:
1) SRP is not supported
2) The extension dialing is not over the VPN, rather direct connect via a SIP/H323 dial peer and translation rule (does not go to the SIP Trunk)
3) Each site has its own AA, Directory, Dial Plan and users are NOT shared among a UC500 multisite.
Steven DiStefano
Configuration Item
Number of sites
Firewall
WAN connection type
  • cgi.tzo.com
  • dup.hn.org
  • www.dynx.cx
  • www.justlinux.com
  • www.zoneedit.com
Codec
Dial Plan
Extension length
Hostname
Wow Thanks for the answer that contains everything.
Brilliant you saved my life on the proposal.
Just changed and got prcining based on SR520-FE-K9
Now a little bit of rejigging of the call plan in the proposals, and were done.
Appreicate your help. and will be refreshing myself on the whole thing before setup.
Thanks again
Graeme
