01-10-2012 05:15 AM - edited 03-21-2019 05:10 AM
The Scenario
-My Customer has 2 sites with Less than 50 user each.
-They currently 3 digit dial between the two locations with their existing phone system (NEC) and the use of a PTP circuit.
-Site 1's extension range is 100-199 & 300-399, Site 2's extension range is 200-299.
The Challenge:
-The Customer would like to take advantage of Cisco SBCS and have all interoffice communications be handled by sending gateway to gateway voice traffic over a VPN , and eliminate the exorbitant cost of the PTP...
-THEY WANT TO MAINTAIN 3 DIGIT DIALING
The Question
-I was told that you must 4 digit dial from location to location via a location # (1 or 2).
-Is there a way around this? Can my customer maintain the 3 digit dialing?
Any configuration help offered is greatly appreciated!
Best Regards,
David
01-10-2012 05:21 AM
HI David,
if you set up site 1 as extension range 200 - 299 and site 2 as 300 -399 and use the UC540/560 multisite then the default intersite dialing will be
Intersite access code + site code + Extension.
ie from site 1 to site 2 extension 301 you ould dial 82301
and from site 2 to site 1 extension 275 you would dial 81275.
BUT
to keep the 3 digit dial you can setup floating extensions in site 1 from 300-399 that do a forward to 82301-82399, you can even give them the same names as the names on the other system and vice versa on site 2
So from site 1 to dial site 2 extension 301 they ould just dial 301
this then is floating ext 301, which is a divert to 82301 and then the UC on site 2 handles the call as normal.
It does give a bit more management on the systems in having ro create each extension 2 and such but it works and we have used it at several customers and after all thats what juniors or trainees are for
Hope this helps
Graeme
01-10-2012 05:30 AM
Graeme,
Really appreciate the input… this is exactly what I was looking for…
David A. Linardy
Advanced Computer Technologies Inc.
Direct: 203.663.1033
Fax: 203.847.2475
www.actweb.com
01-10-2012 06:15 AM
Hello David,
Graeme is correct, as that would be the only way to use 3 digit dialing if the unit is being maintained by CCA. If this is a CLI administered unit, the dial-peers for the multisite dialing can be modified so that the access code is not required. You would just have to modify the outgoing and incoming dial-peers on both sites to accomplish this. Just keep in mind, that using CLI on a CCA supported unit could void your support with Small Business Support for that configuration.
Thank you,
Darren
