Multiple DID range on E1
paulstocker
Is it possible to have two different DID ranges on one E1 interface??
sanjsinh
It is possible to have that as long as there are no overlapping patterns. So for example if there are two ranges which may have overlapping numbers, say 9236-6xxx, 9181-6xxx, with a system which has 4 digit extension, then that will not work.
That is an enhnacement for next release.
Sanjay
How is the configuration for that?
I have only one in the range: 5550260401
and 29 from: 5558618870 to 55586118899.
So the range is not overlaping. How can I configure both ranges to work in BE 3K ?
