Multiple SIP trunk connections on a UC540
Audy Bautista
Is the UC540 capable of handling 2 SIP trunk connections to 2 different providers?  Thanks.
5 Replies 5
Maulik Shah
Level 5
Level 5
Not supported via CCA at this time - something we are looking to add in the next release. More info can be got on the below:
https://supportforums.cisco.com/docs/DOC-9830
Audy Bautista
Is it supported via CLI at least? If not on the UC540, how about the UC560?
Audy Bautista
audy@rfa.com
Cell: 646-210-0935
Direct: 212-659-4833
David Hornstein
Level 7
Level 7
Hi Andy
Maulik Shah answered your question with the following info;
https://supportforums.cisco.com/message/3087577#3087577
Audy Bautista
Awesome, thank you!
Does UC500 support multiple SIP trunks?
The  UC500 can have SIP trunks to different service providers which may be  required in some cases for least cost routing etc. This is an optional  Supplemental Feature that is not configured by CCA 2.2 but requires CLI  expertise. This feature is supported on the UC500 software pack 8.0.0 or  later - CLI configuration is at http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-multi-registrars.html .
FrostPuppy
I had a similar question to this.
Can I have two definitions (accounts) for the same ITSP (Engin) configured?
i.e. on a UC560 can I have two SIP trunks configured to Engin and route calls based on originating DN.
Before you ask why
I have multiple ISDN DID ranges for inbound calls.
My Engin SIP trunks are configured to SET the outbound caller-id to a particular number so return calls come back to reception. I need a second user group to caller-id with a different number when going outbound via SIP hence the second trunk.
