11-09-2011 12:49 AM - edited 03-21-2019 04:55 AM
Hello, I have a two sites' environment with an UC520 (2xBRI) on each and the customer want to be able to use all the pstn lines available at both sites.
This means, if a site has all the pstn lines busy the call is routed to the other UC500, is that possible?.
Thanks in advance.
11-09-2011 08:28 AM
That should be possible. You would just need an extra set of dial-peers, with a higher "preference" value that would send the call to the other site if all local circuts are busy.
Thank you,
Darren
11-09-2011 09:59 AM
Hello Darren, thanks very much for your answer but we need to decide if buying CCME or UC500 and we don't have any way of testing it, could you?
Thanks in advance.
11-09-2011 11:05 AM
I really can't see any reason for this scenerio to not work, unless configured incorrectly. Unfortantely, I just do not have the time available to set this up in that lab right now.
Thank you,
Darren
11-09-2011 05:37 PM
You have a lot of options here. But only possible using CUCME on the ISR not UC500.
Your failover options are as follows
Once you have choosen a failover mechanism you would need to setup LLQ QOS and configure your dial-peers. I would suggest calling a Partner or getting Smartnet Onsite to help configure your solution because it requires a lot of configuration. I know because I have done it many times over.
11-17-2011 08:17 AM
Unfortunately I'm not going to close this open loop, we decided to buy CCME instead UC500 to solve this need after evaluating the risks. If anyone finally were able to test it I would appreciate sharing the experience.
Thanks to all !
