06-28-2011 05:17 PM - edited 03-21-2019 04:17 AM
GReetings to all,
I have a UC520 and I have a 1 SIP inbound that rings a blast group to ring the phones around my house, but I would like to have it so when someone leaves a voice mail that the MWI goes on all the phones...
I found an old post (from 2008)...
" x511 is a shared line with a corresponding GDM mailbox
When an incoming call comes in to x511 it is immediately forwarded to the blast group at 512, and as a result, x501, x502, and x503 ring. After 15 seconds (or whatever the no answer timer is set to), the call goes to voicemail. Because the call went to x511 first, it winds up in mailbox 511. After the message is left, an MWI ON message is generated for x511, which results in the envelope icon being displayed next to the x511 button on each of phones A, B and C."
However, I can't seem to get this to work. Has anyone implemented something like this (or this) and gotten it to work?
Also, is there a way to change the outgoing message on a GDM? I tried to log in to the mail box but it just tells me that it's not valid... Sorry I'm still alot new to most of this...
Tom
06-28-2011 08:47 PM
Hi Tom,
If you are configuring this system using CCA then you can make every extension a member of that GDM, this may not have been done.
A tell-tale-sign of you being a member of the GDM is that when you log into your VM (Pressing the envelope button) you should be presented with option "9" usually straight away if there are no VM's on your personal extension.
The other alternative you can consider is setup a floating extension instead of a Blast Group GDM and set your BG timer to point to this Floating Extension and also set a Permanent CFWall on it to the VM, you can then assign this FE to a button on one of the phones and you should be able to log into its VM if you are a member of it
There may be some other ways to skin this cat, but they require a little more depth.
Hope this helps you out
Cheers,
David.
06-29-2011 09:42 AM
Ok, that helps, but how do you monitor that for VMs?
06-29-2011 03:38 PM
Hi Tom,
Pretty Good question bud
Actually I do not have an answer for that, I would have though as being a member of it, you would see an envelope on the screen or even the light glowing, hmmmmmm man on a mission now to get an answer for this one
Will check and see what notifications can be applied to a GDM, maybe the best way would be to just use IMAP for now and have one person retrieve it (But not delete it) and distribute it to the appropriate person(s).
Is IMAP and option for you?
Cheers,
David.
07-01-2011 07:35 AM
This can work like you want it to. The trick is, you need to be able to transfer directly to a voicemail. CCA does this with the leading digit 6:
511 w/ GDM call forward all to 512 Blast group.
512 Blast group to 6511
You could also make 511 a personal mailbox in this scenario, then have one password to check that voicemail box. Either way you prefer.
Adam Compton
