MWI not working after Upgrade to Pack 8.1.0
salik.makda
After upgrading UC520 from Pack 7.0.3 to 8.1.0, MWI stopped working
Extension 222
MWI On A800...
MWI off A801...
below is debug output from CUE
2307 06/30 08:21:01.515 voicemail mwi "refreshMWI" 222 0
2307 06/30 08:21:01.541 voicemail mwi "setMessageWaiting" 0x0000000000000000 222,true
2307 06/30 08:21:01.544 voicemail mwi " job state" MessageWaitingThread.addJob:
Messages-Waiting: yes
Message-Account: sip:222@10.1.10.1
Voice-Message: 1/0 (0/0)
Fax-Message: 0/0 (0/0)
2307 06/30 08:21:01.544 voicemail mwi " job state" MessageWaitingThread.addJob: numJobs=1
3126 06/30 08:21:01.554 voicemail mwi " job state" MessageWaitingThread.run: extn=222, numJobs=0
3126 06/30 08:21:01.554 voicemail mwi " job state" http://localhost:8080/mwiapp?extn=222&state=1
3632 06/30 08:21:01.582 ACCN SIPS 0 getOriginialCalledNumber:null
3632 06/30 08:21:01.582 ACCN SIPS 0 Call.created() SIPCallContact[id=143,type=Cisco SIP Call,implId=E07EC20D-0130-1000-42BC-6E19984DC3FA,active=false,state=null,inbound=false,handled=false,locale=en_US,aborting=false,app=App[name=ciscomwiapplication,type=Cisco Script Application,id=3,desc=ciscomwiapplication,enabled=true,max=6,valid=true,cfg=[ApplicationConfig[,name=ciscomwiapplication,id=3,type=Cisco Script Application.description=ciscomwiapplication,enabled=true,sessions=6,script=SCRIPT[setmwi.aef],access=0,privilege=1,script=SCRIPT[setmwi.aef]]]],task=17000000074,session=null,seqNum=-1,time=1309436461581,cn=null,dn=null,cgn=null,ani=null,dnis=null,clid=null,atype=OUTBOUND,lrd=null,ocn=null,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=null,route=null,port=null,aborting=false,transferring=false,disconnecting=false]
3632 06/30 08:21:01.585 ACCN SIPS 0 Port.init called by contact manager:Port[type=Cisco SIP Channel,id=8,implId=8,active=true,state=IN_USE]
3632 06/30 08:21:01.586 ACCN SIPS 0 accept called - dest=A800222
3632 06/30 08:21:01.586 ACCN SIPS 0 accept called - timeout=5000
3632 06/30 08:21:01.586 ACCN SIPS 0 getOriginialCalledNumber:null
3632 06/30 08:21:01.587 ACCN SIPS 0 accept: call contact got is:SIPCallContact[id=143,type=Cisco SIP Call,implId=E07EC20D-0130-1000-42BC-6E19984DC3FA,active=true,state=CALL_INITIATED,inbound=false,handled=false,locale=en_US,aborting=false,app=App[name=ciscomwiapplication,type=Cisco Script Application,id=3,desc=ciscomwiapplication,enabled=true,max=6,valid=true,cfg=[ApplicationConfig[,name=ciscomwiapplication,id=3,type=Cisco Script Application.description=ciscomwiapplication,enabled=true,sessions=6,script=SCRIPT[setmwi.aef],access=0,privilege=1,script=SCRIPT[setmwi.aef]]]],task=17000000074,session=null,seqNum=-1,time=1309436461581,cn=null,dn=null,cgn=null,ani=null,dnis=null,clid=null,atype=OUTBOUND,lrd=null,ocn=null,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=null,route=TR[num=290],port=null,aborting=false,transferring=false,disconnecting=false]
3632 06/30 08:21:01.587 ACCN SIPS 0 getOriginialCalledNumber:null
3632 06/30 08:21:01.587 ACCN SIPS 0 Call.associated() SIPCallContact[id=143,type=Cisco SIP Call,implId=E07EC20D-0130-1000-42BC-6E19984DC3FA,active=true,state=CALL_INITIATED,inbound=false,handled=false,locale=en_US,aborting=false,app=App[name=ciscomwiapplication,type=Cisco Script Application,id=3,desc=ciscomwiapplication,enabled=true,max=6,valid=true,cfg=[ApplicationConfig[,name=ciscomwiapplication,id=3,type=Cisco Script Application.description=ciscomwiapplication,enabled=true,sessions=6,script=SCRIPT[setmwi.aef],access=0,privilege=1,script=SCRIPT[setmwi.aef]]]],task=17000000074,session=null,seqNum=-1,time=1309436461581,cn=null,dn=null,cgn=null,ani=null,dnis=null,clid=null,atype=OUTBOUND,lrd=null,ocn=null,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=null,route=TR[num=290],port=Port[type=Cisco SIP Channel,id=8,implId=8,active=true,state=IN_USE],aborting=false,transferring=false,disconnecting=false]
3632 06/30 08:21:01.588 ACCN SIPS 0 MAKE_CALL_FAILED:Outbound call failed : All Call ids=SIP Call Contact ID:143,SIP Port=Port[type=Cisco SIP Channel,id=8,implId=8,active=true,state=IN_USE],Exception=java.lang.UnsupportedOperationException: [SIP-Dummy-MT-77 dn=null no media] method not supported,Failure reason=null
3632 06/30 08:21:01.590 ACCN SIPS 0 EXCEPTION:java.lang.UnsupportedOperationException: [SIP-Dummy-MT-77 dn=null no media] method not supported
3632 06/30 08:21:01.593 ACCN SIPS 0 EXCEPTION:  at com.cisco.jasmin.impl.ds.DummyMediaTerminal.setHost(DummyMediaTerminal.java:34)
3632 06/30 08:21:01.595 ACCN SIPS 0 EXCEPTION:  at com.cisco.wf.subsystems.callcontrol.Port.createMediaTerminal(Port.java:892)
3632 06/30 08:21:01.597 ACCN SIPS 0 EXCEPTION:  at com.cisco.wf.subsystems.callcontrol.Port.accept(Port.java:1009)
3632 06/30 08:21:01.599 ACCN SIPS 0 EXCEPTION:  at com.cisco.wf.steps.ivr.CreateCallStep.execute(CreateCallStep.java:357)
3632 06/30 08:21:01.601 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.obj.WFBeanStep.executeImpl(WFBeanStep.java:166)
3632 06/30 08:21:01.602 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.obj.WFStep.execute(WFStep.java:175)
3632 06/30 08:21:01.604 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.obj.WFWorkflowTask.executeStep(WFWorkflowTask.java:494)
3632 06/30 08:21:01.606 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.engine.core.WFEngineWorkflowTask.executeStep(WFEngineWorkflowTask.java:124)
3632 06/30 08:21:01.608 ACCN SIPS 0 EXCEPTION:  at com.cisco.app.impl.WFWorkflowAppDebugTaskWrapper.executeStep(WFWorkflowAppDebugTaskWrapper.java:382)
3632 06/30 08:21:01.610 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.obj.WFWorkflowTask.execute(WFWorkflowTask.java:360)
3632 06/30 08:21:01.612 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.engine.core.WFEngineWorkflowTask.execute(WFEngineWorkflowTask.java:79)
3632 06/30 08:21:01.614 ACCN SIPS 0 EXCEPTION:  at com.cisco.app.impl.WFWorkflowAppDebugTaskWrapper.execute(WFWorkflowAppDebugTaskWrapper.java:702)
3632 06/30 08:21:01.615 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.engine.core.TaskManager.runTaskNormally(TaskManager.java:421)
3632 06/30 08:21:01.617 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.engine.core.TaskManager.runTask(TaskManager.java:376)
3632 06/30 08:21:01.619 ACCN SIPS 0 EXCEPTION:  at com.cisco.wfframework.engine.core.Invoker.invoke(Invoker.java:85)
3632 06/30 08:21:01.621 ACCN SIPS 0 EXCEPTION:  at com.cisco.app.impl.ApplicationManagerImpl.invoke(ApplicationManagerImpl.java:2551)
3632 06/30 08:21:01.623 ACCN SIPS 0 EXCEPTION:  at com.cisco.app.Application.invoke(Application.java:630)
3632 06/30 08:21:01.625 ACCN SIPS 0 EXCEPTION:  at com.cisco.wf.subsystems.http.sysservlet.ApplicationInvoker.doGet(ApplicationInvoker.java:244)
3632 06/30 08:21:01.626 ACCN SIPS 0 EXCEPTION:  at com.cisco.wf.subsystems.http.sysservlet.ApplicationInvoker.doPost(ApplicationInvoker.java:80)
3632 06/30 08:21:01.628 ACCN SIPS 0 EXCEPTION:  at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
3632 06/30 08:21:01.630 ACCN SIPS 0 EXCEPTION:  at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
3632 06/30 08:21:01.632 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.core.ServletWrapper.doService(ServletWrapper.java:405)
3632 06/30 08:21:01.634 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.core.Handler.service(Handler.java:287)
3632 06/30 08:21:01.635 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
3632 06/30 08:21:01.637 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
3632 06/30 08:21:01.639 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
3632 06/30 08:21:01.641 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.service.http.HttpConnectionHandler.processConnection(HttpConnectionHandler.java:213)
3632 06/30 08:21:01.643 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:416)
3632 06/30 08:21:01.644 ACCN SIPS 0 EXCEPTION:  at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:501)
3632 06/30 08:21:01.646 ACCN SIPS 0 EXCEPTION:  at java.lang.Thread.run(Thread.java:595)
3632 06/30 08:21:01.649 ACCN SIPS 0 setMessageWaiting: genSubNot=false, genUnsolicited=false, dn=222
3632 06/30 08:21:01.649 ACCN SIPS 0 neither sub-notify or unsolicited is enabled
3632 06/30 08:21:01.656 ACCN SIPS 0 getOriginialCalledNumber:null
3632 06/30 08:21:01.656 ACCN SIPS 0 App has tried to abort call, reason=[com.cisco.app.ApplicationTaskInactiveException: Task id: 17000000074, task no longer running], but the call stayed in STATE_INITIATED_IDX, let the recovery thread recovers SIPCallContact[id=143,type=Cisco SIP Call,implId=E07EC20D-0130-1000-42BC-6E19984DC3FA,active=false,state=CONTACT_ABORTED,inbound=false,handled=false,locale=en_US,aborting=false,app=App[name=ciscomwiapplication,type=Cisco Script Application,id=3,desc=ciscomwiapplication,enabled=true,max=6,valid=true,cfg=[ApplicationConfig[,name=ciscomwiapplication,id=3,type=Cisco Script Application.description=ciscomwiapplication,enabled=true,sessions=6,script=SCRIPT[setmwi.aef],access=0,privilege=1,script=SCRIPT[setmwi.aef]]]],task=17000000074,session=null,seqNum=-1,time=1309436461581,cn=null,dn=null,cgn=null,ani=null,dnis=null,clid=null,atype=OUTBOUND,lrd=null,ocn=null,odn=null,uui=null,aniii=null,ced=null,lrvmn=null,ocvmn=null,route=TR[num=290],port=Port[type=Cisco SIP Channel,id=8,implId=8,active=false,state=IDLE],aborting=false,transferring=false,disconnecting=false], appCallListener=null, port.call is not null, route is active for port
0 Replies 0
