MWI stop working after update to 8.6.1
Hi everyone.
After update the UC560 to 8.6.1 the phones don't receive any MWI notification any more (no red lights and no envelopes on the screen).
The MWI numbers are correctly configured.
ephone-dn  599
number A801.... no-reg primary
mwi off
ephone-dn  600
number A800.... no-reg primary
mwi on
I can see the same numbers in the CUE GUI MWI>Settings.
I've tried to reset the CUE an the CME and call to that numbers
UC_560#csim start A8012012
csim: called number = A8012012, loop count = 1 ping count = 0
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Any ideas?
Thank you.
8 Replies 8
paolo bevilacqua
Try "unsolicited notify" method.
it's simpler to configure, and I've never seen it fail (including 8.6.1).
Hi.
I will try.
Thank you.
Best Regards
David Trad
Hi Mate,
You can also remove them and re-add them, this has worked in the past but it could be a newly introduced bug as well :-\
Cheers,
David Trad.
Sent from Cisco Technical Support Android App
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I tried that. even change the MWI numbers.
Hello Waldo,
Please check if you have the following under "Voice service voip" sip subsection:
bind control .......
bind media .......
If you have them please remove them by entering - "no bind control" and "no bind media".
HTH,
Alex
*please rate helpful posts
Thaks but I don't have these commands.
I fixed the problem adding this to the unity dial-peer.
Incoming called-number A80[01]….
The final configuration.
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 3099
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
Thanks a lot to everyone, this forum is very helpfull.
Cheers
Hi Waldo,
Please check then if you have "connection-reuse" under "sip-ua"
If you have it there please do the following
sip-ua
no connection-reuse
and then refresh the MWI.
HTH,
Alex
*Please rate all helpful posts
Check out this post:
https://supportforums.cisco.com/message/3692011#3692011
Same issue with previous upgrades.  Should sort you out.
