05-26-2012 09:28 AM - edited 03-21-2019 05:50 AM
Hi CCA Team,
I imagine that at times leaves the CCA 3.2.1, I do not see the announcement but already I read the instructions for using Cisco Jabber then will be the last frenetic hours before the release... Now, before you take a few days of respite, I would like to ask you a question!
You will never addressed the possibility of including even more sip trunks to different ITSP?
I can see that the argument has been proposed/debated several times in recent years, now whereas, if I remember correctly, the latest versions of CME support this possibility, why not put this in CCA? Even so basic, and retaining the ability to use the old syntax if the problem can be the reverse compatibility... but I believe that, even within the SMB, is particularly useful to be able to connect multiple ITSPs or manage a redundancy or anything that provides authentication and signing of several servers.
Arturo.
05-26-2012 11:46 AM
Not only the CCA, but actually the IOS doesn't support authentication for multiple SIP trunk.
Sure that's laughable and surprising,
05-26-2012 11:55 PM
Hi Paolo,
the IOS version 15.x has several changes on command from the CLI; surely you can define multiple registrars but, clearly, in collision with CCA. For this reason I have not wanted to venture into understanding what are the limits, maybe you have some extra knowledge in the use of CUCME from CLI. I would not adventured, so I still have some hope!
uca(config)#sip
uca(config)#sip-ua
uca(config-sip-ua)#registrar ?
<1-6> Registrar Index Value for configuring multiple registrars
WORD Registrar Server address
dhcp Registrar Server address provision via DHCP
73,
Arturo.
05-27-2012 05:11 AM
The issue is not with multiple registrars, but authentication for outbound calls.
Anyway, using the CLI is very easy, and produces better results in less time than GUI, that by their nature, are always limited.
05-30-2012 06:32 PM
Hi Arturo,
CCA 3.2 was supposed to have multiple ITSP support, but this was sometime last year when I was pushing hard for this and heard that it may come out in this release (I drafted a big list for the dev team - More like a wish list I guess) of things that CCA 3.2 would need, I was advised that some of them would make it on the list to be added.
I am guessing now that they were not, and if CCA 3.2 does not have multiple ITSP support, then this is a shame as it has been long awaited by many people, 15.X IOS I believe does have multiple ITSP support, so it should be able to work.
But you are right, and you should keep lobbying Cisco to introduce it and don't stop, I know I never did But I don't work with Cisco products full time at the moment (Only maintain clients that wont move on and keep hassling me to do their work), so lobbying for me is not so important at the moment, but still keep a close eye on developments just in case I start working with Cisco products full time again, plus I can give them a break now LOL
Cheers,
David.
05-31-2012 06:19 PM
I have come to the conclusion that the CCA team is no longer listening.
06-01-2012 11:36 PM
Hi Scott,
On the contrary they are watching/observing, but they are limited to what
they can do, you really need to direct your concerns to the product manager
of CCA, I don't know who that is now, but in the olden days they would pop
their head in on these forums and participate, haven't seen that in a long
time.
Cheers,
David Trad
"Sent from my Acer Iconia A500"
On Jun 1, 2012 11:44 AM, "smproductions" <
06-02-2012 03:34 AM
Having raised a selection of requests over the past few years to no avail, I can qualify the above statement.
