Only 7 PoE ports working on UC540
asho22
We are configuring a UC540 and it looks like the 8th LAN port will not work.  We have 7 phones connected and working, when we connect the 8th phone it does not work.  We have swapped cables and phones and ports but this is not the issue.  The 8th connected phone will not work, is this due to a limitation of the UC540?
Ashleigh
John Platts
Level 4
Level 4
The PoE capacity of a UC520 or UC540 is 88W. If you are using color screen 7900 series phones with the UC540, you might not have enough PoE capacity to power all 8 of your phones. You will probably need to use a power cube on one of your phones, or connect your extra phones to a separate PoE switch.
You can find out the PoE usage by using the show power inline command. Here is sample output from that command:
test-uc540#show power inline
PowerSupply   SlotNum.   Maximum   Allocated       Status
INT-PS           0        88.000    47.000          PS GOOD
Interface   Config   Device    Powered    PowerAllocated
Fa0/1/0     auto     Unknown  Off        0.000 Watts
Fa0/1/1     auto     Unknown  Off        0.000 Watts
Fa0/1/2     auto     IEEE-3   On         7.000 Watts
Fa0/1/3     auto     IEEE-3   On        12.000 Watts
Fa0/1/4     auto     IEEE-3   On         7.000 Watts
Fa0/1/5     auto     IEEE-3   On         7.000 Watts
Fa0/1/6     auto     IEEE-3   On         7.000 Watts
Fa0/1/7     auto     IEEE-3   On         7.000 Watts
craig.corbett
Level 2
Level 2
Not sure if this applies here, but some devices draw more power than others and there may be a limit on the UC540. What phones are you using? Any other POE devices in use?
  Thanks John for that command very useful.
