problem with a Voip solution between a SPA3102 and a PAP2T
I have a problem with a Voip solution between a SPA3102 and a PAP2T through a radio link. The communication disconnects/falls at random between minute 1 and minute 5. I tried the service quality and CCQ changes from 100% to 95% with only a 80 K bandwith for the communication.
Andrey Cassemiro
Hi rubem
It would be so helpful if you get the logs from both atas to see which one is disconnecting and the disconnect reason.
In the community you cAn find a guide explaining how to get this sip logs.
Tks
Rgds
Andrey
