Problems with 9971 and SIP Trunk
ai.solutions
Hi all,
Having a few problems with the new software pack compared to the last version. Now, im trying to test the support of the 9971... so thats the new element here... however I seem to be having problems with SIP Trunks here also (perhaps its the two elements combined).
Im using CCA 3.2.1
Firstly if I start off with a factory default configuration, I run through the telephony setup wizard (provision the first test phone a 7945 - Extension 201)
I then go and configure the networking, VLANs and IP addresses to my test environment.
Next I setup my SIP trunk and DID to ring ext 201. This all tests fine for both incoming and outgoing calls on the SIP trunk.
As soon as I provision the 9971 with ext 202, outgoing calls work fine but incoming calls via the SIP trunk no longer work.
10 Replies 10
pennautomotive
Does your UC happen to be behind another firewall?
