random incoming FXO calls do not connect
mark
I have a UC520 with 4 anolog lines.  It seems that calls at random will not connect.  We get about 50 calls a day and when we pick up the phone the call does not connect, then the caller calls back it it connects.  I don't know if it is specific to one port, we recently moved offices and it was doing the same thing at the old office.  So it is not a line because we have new lines to the system.  Some calls work fine and others do not connect the call.  Is there any commands that I can add to the fxo ports to get this working.  I just have a standard config on the ports, see below.  Any help is much appreciated.
voice-port 0/1/0
connection plar opx 206
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
caller-id enable
Hi Mark,
You can also try with "no battery-reversal" or "battery-reversal" under all of the FXO ports configuration. If you are using now battery reversal change it to the other. You may not see battery-reversal because it is default setting for the voice port you will see only no battery-reversal.
Also you can take a look at this document:
www.cisco.com/en/US/docs/ios/12_2t/12_2t2/feature/guide/ft_ansds.html
HTH,
Alex
*Please rate helpful posts
David Trad
Hi Mark,
Can you please do a debug on some incoming calls, and just advise which ones worked and which ones didnt so I can gather the info from thed bugs much quicker.
The process:
ROUTER# term mon
ROUTER# deb vpm sig
You will see a fair bit of chatter on the screen when you do this, make sure your putty session is set to capture as many lines as possible, I like to set it to 200000 just to be on the safe side
Post your debug logs when done so they can be inspected.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi Mark,
HTH,
Alex
The "no Battery-reversal" command did the trick.  The system has no more mysterious hang ups.
Thank you,
