11-01-2013 06:40 AM - edited 03-21-2019 07:53 AM
Maybe I'm wrong on this one but you can't connect a UC560 directly to an amp (Bogen) without some kind of paging attendant device, correct? One job we did, the customer already had an "AT&T Page Pal" which connected to the UC560 via an FXS port and worked wonderfully. Problem is that "Page Pal" device is something like 20 years old and hard to find. Is there a current version of this type of device?
11-01-2013 09:08 AM
You can use a SIP paging device, etc. Depends on th exact requirements.
11-01-2013 09:10 AM
Can you be specific. Maybe some commonly used brands/models?
11-01-2013 09:13 AM
You can check algosolutions.
11-01-2013 09:28 AM
Am I correct in assuming that you can't simply hook up an FXS line to the input terminals of an AMP? A "SIP paging device" is necessary?
11-01-2013 09:46 AM
Hello James,
The easiest solution is to purchase a Bogen TAMB2 and connect to the FXS port. These are cheaper than SIP Algo solutions and work well. I have only run into one instance where it did not work out and that is when the client wanted to do a combined internal/external page. If they want to do that, you need a Algo Paging Interface and tie this into the system using multicast only.
Good luck
11-07-2013 10:03 AM
Thank you both. I think we will be going with the Bogen TAMB2 device but can you elaborate a little bit on how to hook it up with a FXS line? Do you terminate a RJ11 for the FXS end and then just strip bare wires to connect to the TAMB?
Any snapshots of existing setups would be awesome (if you have any)
