03-30-2012 12:59 PM - edited 03-21-2019 05:35 AM
Hi all,
Firstly, let me apologize for my ignoreance in all matters Cisco - I'm slowly learning!
For some reason recently when I reconfigured our UC540 via the CCA (created a additional VLAN with DHCP, disabled DHCP on the DATA VLAN), I am now no longer able to access it at all. I've tried plugging my laptop in to each of the ports to pick an IP address but I get nothing. I have a laptop hooked up to the console port and was able to login via putty but don't really know what I'm doing!
I recently had someone work on it for me and they saved a backup of the configuration when they were done (to somewhere within the UC540).
Would someone be willing to tell me the steps I need to restore that backup via the CLI? I found this but it doesn't actually tell you the commands to use:
http://uc500.com/en/how-backup-upgrade-and-restore-uc500-cue-clistepbystep?destination=node%2F837
Many thanks!
Bob
03-30-2012 01:11 PM
Hello Bob,
Most likely, they saved the backup to flash. You can look to see if the file is there by doing the following:
UC540# sh flash
Then looking for the backup file. The name depends on what they called it. You would then have to copy that file to the startup config:
UC540# copy flash:backup.bak startup (backup.bak would be the name they saved it as.)
UC540# reload
If they backed up using CCA, it will be on the computer they used for CCA, not in flash. And restoring is not the same.
I would really suggest that you call support to help so that you don't end up loosing things. Support - 1-866-606-1866.
Thank you,
Darren
03-30-2012 01:32 PM
Hi Darren,
MANY thanks for the super quick response! I have located the file (the only one updated on the day we did the work), called 'fresh1.cfg' but when I attempt to restore it using the command above, I get a message saying:
Destination filename [startup-config]?
I would definately call support if it was free but I'm afraid we're a tiny company and simply can't afford it right now so I'm teaching myself Cisco (we're on a small Caribbean island so no courses either!).
Thanks again for your help, much appreciated!
Bob
03-30-2012 01:42 PM
Hello Bob,
It is asking to confirm that you want to copy that file to the [startup-config]. You can just hit enter there.
Just to be safe, I would suggest using the following command before proceeding since I am not positive the file you are copying is the correct one.
UC540# copy run flash:backup.cfg
Hit enter on the destination question.
Once that has saved, then run the commands from the earlier post.
Thank you,
Darren
