SIP configuration for CenturyLink
mml4cisco
I need to setup the UC520 SIP Trunk to CenturyLink. Within CCA, I don't see CenturyLInk listed from the vendor list. Anyone have experience with CenturyLink configuration?
johschaf
Level 4
Level 4
Hello mml4cisco,
There is not a SIP trunk template for CenturyLink. You can create a generic SIP profile for CenturyLink based upon the SIP trunk settings they have told you to use.
If you have questions about the SIP trunk configuration, feel free to post that here as well(just be sure to remove usernames/passwords if necessary).
Hope this helps.
-john
