SIP trunk incoming call SPA3102
hspot
I need guidance with SPA3102.
Line 1 is connected to a SIP trunk and I can make calls (outbound) from the analog telephone (ATA)
PSTN Line is also connected to the same SIP trunk, and I need to receive calls (incoming) from the trunk number to the analog telephone (ATA). On the web I see the incoming call ID number, but the phone does not ring.
SPA
Internet (ok connected)
Ethernet (ok connected)
Phone (ok analog connected)
Line (disconnected, I don't use it, I don't have a landline telephone provider)
I'm only looking to receive calls from the trunk to receive them on the analog phone.
hspot
Solved with FreePBX.
Hi! Good that you have solved...
Can you share the setup of SPA3102 and Freepbx (obviously obfuscating sensitive data)?
Thank you!
No problem
Extension config SPA, Line 1
Proxy: IP FreePBX
User ID (custom extension)
Password
FreePBX
Trunk connection
Outbound CallerID (phone number of trunk)
Username
Secret
SIP Server
Inbound route to custom extension.
Incoming call to trunk 442xxxxxxx ring into analog SPA line.
Good!
Thank you so much
