Smart Call Connector Toolbar 2.2 Windows Home Premium queries
sallystephenson
Is Windows 7 Home Premium supported?
Have managed to install for one user, but had to disable Outlook add-in as it meant the user couldn't search in Outlook while they were on a call and even after the call was complete - they had to restart Outlook to rectify.
For the other user I couldn't get it installed at all - got the ccSIPoid.dll is missing error although they were using Outlook 2010. (I've seen above users with this issue on Outlook 2013).
Help!
paolo bevilacqua
Cisco is not maintaining compatibility with current Microsoft OS and applications.
So if somethign doesn't work they will tell you - "not supported".
You can open a case with them to verify.
