SPA 112 -placing calls on local WIFI
Jan Anderson
Community Member
Dear community
Just bought a SPA 112 that seems to be working just fine, apart from one thing:
We can't seem to place local calls between the two lines (long cable between two buildings).
It rings but goes quiet and hangs up after making a call and the other side picks up. Any chance of a hint?
Also curious if I need to set something specific for use in Sweden? Seems to work fine, but still.
Should I tweak something else? The dial plan?
thanx very much for any help!
Jan A.
Jaime Valencia
SPA endpoints are supported in the SMB community within CSC
java
if this helps, please rate
Thanx Jaime,
Does that mean I should post my question elsewhere?
Not sure what acronyms SMB and CSC mean?
thanx again
Jan
Yes
SMB = small business
CSC = Cisco Support Comunity
Hover over the directory option on top of the page to get the full directory.
java
Thanx Jaime, I will head over there.
