11-03-2017 10:05 AM - edited 03-21-2019 10:41 AM
I am now trying to update the firmware and facing some challenges (updating from 5.2.12 to 5.2.13).
Here are the steps I am taking:
1) Obtained IP address from SPA (unit is unlocked)
2) connect internet to Internet port (blue)
3) connect laptop to Ethernet port (yellow). I have also tried to update by removing the Ethernet cable and only using the internet.
4) Run firmware upgrade program (i.e. "upg-spa2102-5-2-13.exe")
5) open browser and download bin file from HTTP site. The 5.2.13 bin file is located as an example (HTTP://192.168.xxx.xxx/admin/upgrade?HTTP://www.mysite.com/spa2102-5-2-13.bin)
6) Admin password has been shut off and provision is enabled
The progress bar keeps going and file does not update.
I checked the links (www.mysite.com/spa2102-5-2-13.bin) in another browser and file downloads.
11-09-2017 01:48 AM
I'm sorry to hear that you are experiencing issues upgrading the firmware on your device.
I can suggest the following - make a backup of your configuration, perform a factory reset on the device and try to upgrade the firmware again.
If you are still experiencing issues with the upgrade procedure please call our support centre for further assistance.
Kris
11-12-2017 12:55 AM
According Eos-EoL announcement for UC560, the support for UC560 is over. As far as I know, Support Centre strictly refuse to provide advice related to EoS product. Unless I missed the Cisco's policy had changed, your advice "to call support" is confusing and useless ...
