SPA 502G Reboot after being set
edgarborchardt87
Community Member
Good mornig.  The problem i have with my cisco ip iphone spa502g when i finish configuring a switch always reboot.
i put an static IP, netmask, gateway. The software version of mi spa502g2 is 7.5.3. i've tried many ways.
fo example: the spa502 has the following data.
DHCP
IP:192.168.3.12
NETAMASK: 255.255.255.0
GATEWAY: 192.168.3.254
When i put other data
 192.168.200.30
255.255.0.0
192.168.200.254
whe it is restarted.
I refresh the software version, but still the same problem. I think it is settings. thank you.
Dan Lukes
Phone will restart as result of major configuration changes. It just need to start with new options.
I'm not sure what's the issue you need to solve. One time restart during lifetime of device seems not to be issue requiring solution, isn't it ?
