SPA-504G daylight saving not working properly (7.5.2b)
Cassius_Smith
I'm having a problem with an installation in Slovakia. The phones don't seem to pick up the DST rule that I have in place there, so the clocks are 1 hour off.
I'm running 7.5.2b firmware, selected GMT+1 with a DST rule:
3/-1/7/2;end=10/-1/7/3;save=1
But the phones don't seem to get the right time.
I've tried removing the hour field but that did not help.
Any ideas?
Cassius Smith
Dan Lukes
Slovakia zone is the same as Czech zone and start=3/-1/7/2;end=10/-1/7/2;save=1 works for me. So problem seems to be elsewhere. There are several setting that affects time offset, including the options delivered via DHCP.
You need to decide either to honor DHCP or maintain local corrections but not both.
Recommended settings for you (I recommend not to honor DHCP as it announce time-zone offset incorrectly in many cases):
Ignore DHCP Time Offset=Yes
Daylight Saving Time Rule=Yes
Time Offset (HH/mm)="" (empty)
Time Zone=GMT+0100
Daylight Saving Time Rule="start=3/-1/7/2;end=10/-1/7/2 ;save=1"
Hope it help.
