06-03-2014 10:17 AM - edited 03-21-2019 08:16 AM
We recently have unplugged the power and tried to replug in. But now, it will not boot. It flashes some light and turns off completely. We have tried use our second Cisco Spa 525g power, it does the same thing, trying to boot but failed. Please help me with the issue and if there is any place can fix it in area around zip code 98004
06-14-2014 01:59 AM
These devices are not field-serviceable. If you are still covered under your warranty we can probably do an RMA and replace the device for you after we do a little bit of troubleshooting to determine if it is a hardware issue.
Give us a call at the SBSC and we can get a support case opened for you.
Cisco Small Business Support Center Contact Numbers
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
*please rate helpful posts*
02-11-2015 11:46 AM
Just had one of these SPA525g2 delivered two days ago from Ring central, exactly the same issue. Unplugged and moved, plugged back in and main red light on top, screen blank, 3 of the call presence light at half light. Repeatedly re cycled but nothing? Help?
02-11-2015 03:25 PM
Follow the chrebert's advice above. Or return the faulty device to seller.
