SPA 8800 sends 500 "Internal Server Error"
Mihail-sfmnt
Hi, I'm using SPA 8800(Software Version: 6.1.7(GW)) with Asterisk 10. FXS works fine no errors were noted, but that's for calls to the PSTN after about then 2 minutes of conversation is cut off communication, while in the CLI Asterisk, I see the following:
- Executing [9363455 @ internal: 1] dial ("SIP/104-00000476", "SIP/363455 @ pstn, 60")
   == Using SIP RTP CoS mark 5
     - Called SIP/363455 @ pstn
     - SIP/pstn-0000047a answered SIP/104-00000476
     - Remotely bridging SIP/104-00000476 and SIP/pstn-0000047a
     - Got SIP response 500 "Internal Server Error" back from 192.168.0.xxx: 5061
     - Executing [h @ internal: 1] noop ("SIP/104-00000476", "ANSWER")
   == Spawn extension (internal, 9363455, 1) exited non-zero on 'SIP/104-00000476'
How can I fix this?
Please add the syslog of SPA8800.
Regards.
Sorry, but the matter was urgent and the gateway was given the diagnosis. I asked him to provide a full report bugs. Once they find something, I'll write here.
