SPA112 Crashes - No dialtone, restart needed - new firmware
triotech0573
Hi All,
I  have a  SPA112  brain new,  with  latest  fw  loaded as  per  Cisco site  Version 1.2.1 (004)
Since  the  first  installation  has  started to  show  the  same   problem as  described  also  in " SPA112 Crashes - No dialtone, restart needed ".
The  SPA  seem  to  last  almost  1  month,  after  will  hang,  the  only  way  to  get  it back  up is  to  power  cycle.
Anybody  knows if  this  problem  has  been  solved  or  if  there  is  some  kind  of  work  around ?
Thank  you for helping
TrioTech
paolo bevilacqua
Wrong forum, post in "small business -SPA phones". You can move your post using the actions panel on the right.
Patrick Born
This appears to be related to https://supportforums.cisco.com/message/3779434#3779434
Patrick
