SPA112 fax issues
Brian Armstrong
We have tried different combinations of settings and are hoping someone can give us some help with the log files. When we try to send a fax the far end picks up but then then it disconnects and we get comm error 2001. It doesn't happen all the time but enough the customer is not happy.
The connection is fiber with a media converter and the ATA has a public IP
The ATA connects to a FreePBX server
We replaced the cabling from the fax to the ATA
The log file is attached.
Any ideas?
Dan Lukes
This log will not help to analyze the issue. It is system log catched by device itself - it carry no information related to voice operations. Turn on syslog&debug messages (highest level) on voice tab and send them to an external syslog server.. It;s different log that the one you attached.
Also, catch the SIP packets.
Fax session is failing either because you are using compressed codec. Or because there is T.38 misconfiguration. Or because fax is selected so high transmission speed. Or because end-to-end IP connectivity is poor.
Captured SIP session will disclose codec used as well as T.38 thinks. You should configure your fax not to use speeds over 9600Bd and it should not use V.34 modulation as well.
