07-20-2012 07:11 AM - edited 03-21-2019 09:49 AM
I have tried to run spa122 config file compiler, which I have downloaded from Cisco web site and it has responded with the following errors:
Error code: spc error: unrecognized parameter name Time_Zone
spc error: unrecognized parameter name Gateway
spc error: unrecognized parameter name Connection_Type
spc error: unrecognized parameter name Default_Gateway
spc error: unrecognized parameter name Static_DNS
spc error: unrecognized parameter name DHCP_Server
spc error: unrecognized parameter name Local_IP
spc error: unrecognized parameter name DNS_Proxy
spc error: unrecognized parameter name DNS_Server_Order
spc error: unrecognized parameter name PPPoE_Password
spc error: unrecognized parameter name Subnet_Mask
spc error: unrecognized parameter name Primary_DNS
spc error: unrecognized parameter name PPPoE_Name
spc error: unrecognized parameter name NetMask
spc error: unrecognized parameter name Static_IP
spc error: unrecognized parameter name PPPoE_Service_Name
Then I have generated sample xml using tool which was in the same zip archive. Adjusted my xml file but the parameter names still were not accepted. Parameter names given in the provisioning Guide also seem to be incorrect. Could you please provide me a list of parameter names with possible values acceptable by compiler.
07-20-2012 04:45 PM
Double check the spc file that you used.
I checked the top two items....
For Gateway, it's actually
Connection_type, is actually
07-20-2012 05:05 PM
I have used these parameter names, but complier has responded with the same errors
spc error: unrecognized parameter name Default_Gateway spc error: unrecognized parameter name WAN_Connection_Type
07-22-2012 01:41 PM
Possibly someone else faced such issue. Please, help.
07-22-2012 09:46 PM
May it happen that compiler does not support these parameters at all?
12-04-2013 01:44 AM
I know it's a little late, but maybe the issue still exists for you.
I think the problem is that you don't use the correct syntax for the spc.
try this: spc --xml xmlconfig.xml newconfig.cfg
(important is the "--xml" parameter. "spc" is the name of the compiler exe)
