SPA502G Italian Language.
mikele1983
Hi to all,
I've successfully upgraded firmware to v7.5.5. So I've downloaded SPA30x_SPA50x_SPA51x_SPA525G_7.5.5_Dicts.zip archive that contains the XML language files.
Into txt I have follow the instruction below:
2.1.2 fill in the Reginal -> Miscellaneous -> Dictionary Server Script with the following script, for example:
serv=tftp://192.168.1.4/;d0=English-US;x0=spa50x_30x_en_v755.xml;d1=Portuguese;x1=spa50x_30x_pt_v755.xml;d2=Danish;x2=spa50x_30x_dk_v755.xml;d3=Swedish;x3=spa50x_30x_se_v755.xml;d4=Norwegian;x4=spa50x_30x_no_v755.xml;d5=Spanish-Mexico;x5=spa50x_30x_es_mx_v755.xml;d6=Spanish;x6=spa50x_30x_es_v755.xml;d7=German;x7=spa50x_30x_de_v755.xml;d8=Dutch;x8=spa50x_30x_nl_v755.xml;d9=Italian;x9=spa50x_30x_it_v755.xml;d10=French;x10=spa50x_30x_fr_v755.xml;
The tftp server send correctly the files but if I write "Italian" in to Language Selection field of telephone no change was applied, the SPA reboots but the display language is English.
What is the error?
Regards.
mikele1983
Problem Solved.
The "Italian" String had to be inserted in the same moment of inserting Script and not subsequently.
So, after I've done that I obtain the italian display language and this is good.
The Dictionary Server Script field must be inalterate to mantain the Italian language, seems to be strange because I dont understand the reason of mantaining that string. I've already send the xml files to the phone, why I must mantain the fields? I've try to clean the script field but I noted that the phone starts into english default language.
