02-07-2014 04:31 AM - edited 03-21-2019 08:04 AM
Hi all, i found small issue
When used in the Russian language in the Caller-ID and UTF-8 encoding,
Russian letter "и" always shown small, with the others, there is no problem
if large letter that shows big character, "и" always shown as small as possible fix problem?
03-06-2014 11:36 PM
Hi, my problem not fixed, i can find solution!
Please help me to fix this basic error
03-07-2014 02:01 AM
There is volunteer forum only. Not all problems, especially firmware bugs, can be solved here.
You can try it (you did already) but if nobody helps here, you need to contact Cisco's support.
Yes, you should pay for it. Even if you are reporting Cisco's own bug. It's the way the Cisco is doing the bussiness.
03-10-2014 02:55 AM
Ok, thx for reply
