SPA504G high pitched noise
scox00001
Hi All,
I have an SPA504G phone, when you lift the handset to either receive or make calls it emits a continuous high pitched sound, the only way to get rid of it is to press the speaker button but then the speaker call quality is affected by a clicking sound.
Has anyone else experienced this and are you aware if it can be fixed?  I have tried replacing the handset with a new one.
paolo bevilacqua
Have it replaced by seller.
David Trad
Hi Steve,
Before you RMA the unit, you should consider checking the following:
  • Network cable to the wall, if there is any form of NEXT occurring it may cause this
  • The Twisty cable from the hand peice to the Desk Phone, if these go faulty they can cause high pitched noises
  • Is the screen showing any forms of lines on it or dimming??
You will most likely do have a faulty handset, but it is always good as a matter of courtesy to fully diagnose the phone before logging an RMA with Cisco or the Cisco Partner... At a guess it is probably a faulty capacitor which is emitting EMF and causing the issue, I had about 6 of these in one batch with the exact problem
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) **
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
