We are trying to provision SPA504G phones as SIP phones on IAD2430.
We have connectivity as IAD<->ESW500 Switch<->SPA504G phone
DHCP running on IAD with option 66 .
TFTP server is enabled for spa$MA.xml SPA504-cfg.xml.
Performed below operations,
1. Factory Reset the phone,
2. Selected "SIP" and disable the SPCP Autodetect.
3. Reboot.
Issue:
1. On the IAD when we perform tftp debugs, we are not even seeing any TFTP requests SPA504-cfg.xml spa$MA.xml from SPA phones.
though SPA phone got the DHCP ip from IAD.
Verified that the
2. But when we enable SPCP Autodetect, it queries TFTP on IAD for SPCP config files.
Below is the config of IAD:
CME#show running-config
Building configuration...
Current configuration : 2802 bytes
version 12.4
hostname CME
boot-start-marker
boot-end-marker
!card type command needed for slot 1
enable secret 5 $1$TiDi$rKHZMLXVWWerwTd.kYa.t0
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool VOICE_POOL
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
option 66 ip 192.168.100.1
ip dhcp pool DATA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
no call service stop
call start slow
call preserve
h245 tunnel disable
h245 passthru all
sip
registrar server
voice register global
mode cme
source-address 192.168.100.1 port 5060
max-dn 10
max-pool 10
authenticate register
tftp-path flash:
create profile sync 0031681135352192
voice register dn 1
number 3000
allow watch
voice register pool 1
id mac 1CDF.0F4B.0003
number 1 dn 1
username 3000 password 3000
codec g711ulaw
username cisco password 0 cisco
archive
log config
hidekeys
interface FastEthernet0/0
description ubi-external
ip address 7.6.15.202 255.255.255.252
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
duplex auto
speed auto
interface FastEthernet0/1.100
encapsulation dot1Q 100
ip address 192.168.100.1 255.255.255.0
ip helper-address 192.168.100.1
ip http server
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 7.6.15.201 10
tftp-server flash:spa1cdf0f4b0003.xml alias \spa1cdf0f4b0003.xml
tftp-server flash:SPA502G-cfg.xml alias \SPA502G-cfg.xml
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
gateway
timer receive-rtp 1200
line con 0
line aux 0
line vty 0 4
login local
transport input telnet
end
CME#
