05-03-2011 04:01 PM - edited 03-21-2019 04:02 AM
Hi Forum
Newbie here.
Is there an easy way to make the SPA504G sound like a "normal" phone for an incoming call ?
I'm looking for the ringing sound that a regular phone (connected to old-fashioned telco) makes for an incoming call.
In Australia, thats two short bursts of buzz or purring sound, repeated after a longer pause.
I've tried each of the installed default ringtones, but they're all fairly unappealing, (and thats being polite).
TIA's for any tips and clues.
05-04-2011 05:25 AM
you can create your own!
Creating and Uploading Ring Tones Using the Ring Tone
Utility (Cisco SPA30X and Cisco SPA50XG only)
To convert a file for use as a ring tone, use the Ring Tone Utility, available at:
https://supportforums.cisco.com/docs/DOC-9944
You must have a .wav file less than 8 seconds in length saved to your computer.
You can also use a sound editor to create the file with the following restrictions:
16-bit PCM mono
8000 samples per second
less than 6000 ms in length
To create a ring tone and upload it to a phone:
STEP 1
Open the Ring Tone Utility.
STEP 2
Enter the IP address of the phone.
STEP 3
Click Browse and navigate to the directory on your computer where the source
.wav file is stored. Select the wav file and click Open.
STEP 4
Click Load Source File.
STEP 5
Enter a name for the ring tone. This name will appear in the display on the phone.
You choose the file name later.
STEP 6
Enter the target. You can have up to two customized ring tones uploaded to the
phone.
STEP 7
(Optional) Click Preview to preview the ring tone. Click Options to change the start
or end positions, or to squeeze or stretch the audio.
STEP 8
Click Upload to Phone to upload the ring tone to the phone. Click OK when the
success status message appears.
STEP 9
Close the open Ring Tone Utility windows.
To create a ring tone and save it to a file:
STEP 1
STEP 2
Enter the IP address of the user’s phone or press Skip to create the ring tone and
save it as a file.
STEP 3
STEP 4
Click Load.
STEP 5
Enter a name for the ring tone. This name will appear in the phone display. You
STEP 6
STEP 7
Click Save As to save the file to your computer. Enter the file name and press Save.
STEP 8
To delete a ring tone from a phone:
STEP 1
STEP 2
STEP 3
Click the Delete button next to the ring tone you want to delete.
STEP 4
Click OK.
STEP 5
Assigning a Ring Tone to an Extension
STEP 1
Log in to the configuration utility.
STEP 2
Click Admin Login and advanced.
STEP 3
Click the Ext
STEP 4
Under Call Feature Settings, in the Default Ring field, choose from the following:
No Ring
1 through 10
User 1
User 2
STEP 5
Click Submit All Changes.
05-04-2011 05:36 AM
Thanks for details.
I click-clack at your link, but it just gives :
05-04-2011 06:45 AM
You may need to ask your partner for it.
It’s a partner tool hence protected where its posted.
In the interim, we've sent this request up the chain to determine whether or not it should be made avail to all.
05-04-2011 01:57 PM
Sorry, but I don't have any "partner" with a tool. Firmly committed to remaining "single".
I've bought a single SPA504G to make some testing and evaluation before buying a bunch more for my small business.
Was hoping to just press a few buttons to make the ring sound suitable and sensible.
And quite surprised such a simple feature seems so complicated.
TIA's
BTW. Using Firmware Version: 7.4.8a
05-05-2011 04:20 AM
03-05-2023 11:32 PM
Hello . you can update the best and most attractive ringtones at Suonerie Gratis
