05-26-2010 04:02 AM - edited 03-21-2019 02:37 AM
I am having a problem trying to setup separate VLAN's for the voice and PC on a 504G (firmware 7.4.4) connected to a Cisco SLM248P switch (firmware 2.0.0.10). Basically with VLAN's turned off the phone receives its IP and configuration via DHCP without any problem. However whenever I setup the phone as such it stops working.
Enable VLAN: Yes
VLAN ID: 1
CDP: No (tried Yes too)
EnablePCPortVLANTag: Yes
PCPortVLANID: 2
The switch port that the phone is connected to is a member of VLAN1 Untagged and VLAN2 Tagged.
After setting up this configuration, the PC connected into the phone can reach other devices on VLAN2 without any issue. The phone however will not pull its IP/config from the DHCP server. I see the DHCPDISCOVER and DHCPOFFER coming from the MAC address of the phone but I never see a DHCPREQUEST or DHCPACK meaning it has received the IP. It just keeps looping thru discover and offer requests over and over. I have also tried running the phone on an older firmware version with the same results.
I also have a SPA525G setup in the exact same manner as the 504 and it works fine.
Unfortunately, I am in a situation where I have a number of offices where there is only one network drop so I need to get this working. Any advice or suggestions would be much appreciated.
Thank you,
Eric
Solved! Go to Solution.
06-09-2010 01:48 AM
Dear Sir;
We have been able to nail down the issue.
- Voice VLAN cannot be 1. Set it to any value starting from 2.
Regards, and please let me know if it works for you
Alberto
05-26-2010 04:34 PM
Dear Sir;
I'll escalate your issue. Engineering would need to test this scenario to see if there is any issue. I'll let you know the resolution. Can you please take some traces? that would help to speed up the resolution.
Regards;
Alberto
