spa504g xml caller id
mbardelmeijer
I have an cisco spa504g voip phone with a configration to connect a xml directory. This works good, but the caller id is not showing and the file with the directory in it is then not called. Is is possible to use this directory to get an caller id?
Example directory file:
<CiscoIPPhoneInput>
<Title>Phonebook</Title>
<Prompt>Prompt text.</Prompt>
<URL>http://192.168.1.74/xml/index.php</URL>
<InputItem>
<DisplayName>Filter</DisplayName>
<QueryStringParam>filter</QueryStringParam>
<InputFlags></InputFlags>
<DefaultValue></DefaultValue>
</InputItem>
</CiscoIPPhoneInput>
index.php file:
<?php
header("Content-type: text/xml");
header("Connection: close");
header("Expires: -1");
<CiscoIPPhoneDirectory>
<DirectoryEntry>
<Name>michel bardelmeijer</Name>
<Telephone>06*********</Telephone>
</DirectoryEntry>
</CiscoIPPhoneDirectory>
Kinds regards,
Michel Bardelmeijer
alexeyhamstr
Hi. what is your firmvare version?
I have SPA504 too, but i can't make the external directory work.
i use string like fnc=xml;url=http://10.1.1.47/book.xml, but getting back error "InvalidXmlURL" on phones console.
I fixed it.
the RIGHT syntaxis in XML Directory Service URL is just http:///
And it doesnt metter what firmware you use
