SPA525G - SCA line ID mapping
Eivind Jonassen
Level 4
Level 4
I'm having some issues with the SCA line id mapping on a 525 phone. Firmware version is 7.4.3. I want the SCA to have Vertical first, but the second call is still appearing on the first line key. The phone is in SIP mode.
I've tried the upgrade from 7.4.2 to 7.4.3, didn't solve anything
Eivind
Eivind,
indeed, I have file a bug for this issue CSCtf11632
Thanks!
-nacho
8 Replies 8
Alberto Montilla
Hi Eivind;
I'm escalating this, so please wait for my colleague answer ;-)
regards
Alberto
Eivind
it's a known issue that we are currently working on it. The BUG id CSCte02124.
Thanks!
-nacho
FYI, I've tried this on a SPA509 phone as well. The issue is reversed on this model. I can't get the same line key to ring for the second call aka Horizontal First.
Eivind
Hi Eivind
do you mean that when you set the SCA like horizontal first in the SPA509G behaves like Vertical first?
Thanks!
-nacho
Nacho,
Yes
/E
Eivind,
Thanks!
-nacho
Nacho,
I see that the bug is resolved. When is the update due??
Eivind
I am having this issue with Line ID Mapping.  I set it to vertical, but the 2nd call rings on the same key. It does not go to the next key
I have updated the firmware to 7.6.2c and have the latest as of 2/27/2018
Is there a fix for this?
