07-30-2012 10:33 AM - edited 03-21-2019 06:05 AM
Maybe a simple answer to a simple question but when downloading the latest firmware for the Cisco SPA525G / SPA525G2 phones the zip folder appears to contain two versions of the latest firmware file?
for example:
spa525g-7-5-2a
spa525g-7-5-2a-bt
What is the difference between the two?
What would be the correct file for the SPA525G2?
Solved! Go to Solution.
08-01-2012 09:09 AM
That is correct. The BT has the upgraded bluetooth stack. They have two different firmwares to allow quicker upgrades for customers who do not have BT headsets.
07-31-2012 12:19 PM
Ok well thanks for the help & support, i am guessing the bt in the firmware file is short for BlueTooth!
08-01-2012 09:09 AM
08-03-2012 04:26 PM
Thanks for taking the time to reply, i searched the net for ages and read the pdf supplied with the firmware but nothing. Kinda guessed it reffered to bluetooth but as the 525g & 525g2 both have bluetooth i couldn't understand why their would be two versions.
