03-06-2011 05:05 PM - edited 03-21-2019 03:45 AM
Dear Sirs,
i'd like to become BLF lamps on an attendant console SPA500S Orange (Solid) when an extension is in the state UNAVAILABLE.
Which string i need to send from asterisk to phone via SIP Notify Subscription to achieve this goal?
Thanks in advance
Gianluca
12-05-2011 09:49 AM
Hallo Patrick,
did U already had some time for checking with your colleges about my "problem" ?
It's something we really need in our office...
Regard,
Edgar
12-14-2011 02:26 AM
Hi Patrick and Cisco,
Sorry if I'm annoying...
But this is a very big problem for us!
(a green LED that supposed to be orange or maybe just off... )
Mean while we tested een Snop and a Mitel where the LED
can be turned off... So we also know the softphone isn't online...
Is there hope it can be "solved" with cisco phones?
12-22-2011 05:32 AM
BumB!! Again...
11-22-2011 08:08 AM
HiHi!
1.) Yes, because its a remote phone... (most of them even a softphone)
Asterisk has a DEVICE_STATE() and those can be:
UNKNOWN, NOT_INUSE, INUSE, BUSY, INVALID, UNAVAILABLE, RINGING, RINGINUSE &ONHOLD
When Asterisk gives back the status RINGING or BUSY the led is red or red blinking. (the way we expect)
But when the status is UNAVAILABLE or UNKNOWN I want the led orange and not green.
2.) Yes, i have... (fnc=blf+sd+cp;sub=104@10.101.1.68)
3.) I'm not sure, I think udp. BUT my environment is a test so I have almost no traffic in my network...
03-05-2015 08:13 AM
This not work becouse SPA500S not understand State:Unavailable.
71827@internal : SIP/71827 State:Idle Watchers 1
71842@internal : SIP/71842 State:Unavailable Watchers 1
71841@internal : SIP/71841 State:Unavailable Watchers 1
71840@internal : SIP/71840 State:Unavailable Watchers 1
71839@internal : SIP/71839 State:Unavailable Watchers 1
71838@internal : SIP/71838 State:Unavailable Watchers 1
71837@internal : SIP/71837 State:Unavailable Watchers 1
71836@internal : SIP/71836 State:Unavailable Watchers 1
71835@internal : SIP/71835 State:Unavailable Watchers 1
71834@internal : SIP/71834 State:Unavailable Watchers 1
71833@internal : SIP/71833 State:Idle Watchers 1
I have all the leds Green but Green shuld be for idle.
Some workaround to segnaling Orange when an Ext is not Registered ?
11-22-2011 06:46 PM
Glad we are making some noise and getting a reply regarding this issue. It has been the bane of my existence for a little while!
Thanks Patrick.
11-23-2011 12:40 PM
Hi Tim,
Can you describe for me why this is such an issue for you please? [Aside from Ed's description]
Reading your description may help my colleagues and I come up with a useful solution.
Patrick
11-23-2011 11:17 PM
Hi Patrick,
Functionality-wise, we may have a receptionist at site A, which has handful of teleworkers not at site A.
These remote handsets may or may not be 'registered' or online all the time.
Having the BLF indicator show the Asterisk state 'unknown' will let them know if they are offline, on call, idle etc etc.
This functionality works with other brands of handset / softphone etc.
Kind regards,
Tim Bowyer
11-24-2011 03:11 PM
Dear all,
not only funcionality-wise this function is usefull, think about the power consumption! It's no use to let a Cisco phone (and all the other periferals on the desk) consume power during the weekends, holidays and overnight.
Rgds,
Jan.
02-17-2012 01:07 AM
Hi Patrick,
Just seeing if we have any movent re this state indication issue?
Cheers,
Tim Bowyer
12-22-2011 05:51 AM
Double bump...
12-22-2011 06:08 AM
Triple bump...
02-29-2012 01:46 AM
And Cisco wil never ever answer again when it get diffcult...
I guess we have to search for telephones of a diffrent brand.
Any ideas?? Or experiance??
02-29-2012 03:19 AM
The SPA5XX only supports dialog-info, and unavailable state is not defined for dialog-info. In order to support the unavailable state it should additionally support pidf, if that is at all possible. Asterisk for instance will not report an unavailable state to a dialog-info subscribed SIP device. I have no experience with other SIP phones.
12-13-2014 10:23 AM
Did you solved this major issue?
Do you still use Cisco phones?
Alex
