SPA5xx - Disable PC port?
Ryan Finnie
Is there any way to disable the PC port outright?  I've got an upcoming deployment of a new office with a dedicated voice VLAN, but VLAN trunking to the phones is not available, and I don't want people plugging PCs into the PC port and getting an address on the voice VLAN.  I don't see an option in the configuration to just disable the port.  Thanks!
bethingt
Ill do some more reasearch but from looking at the interface of the phone there is not a way of disableing the PC port. What are you useing for a call manager?
Brian
Asterisk 1.6, SIP.  The phones will be provisioned via TFTP, if that matters.
If you are able to do port security on your switch you may be able to only allow the mac address of the phone to traverse the port. Hope this helps!!!
Brian
