SPA9000, SPA400 & SPA502 SYSLOG DEBUGGING
bodgeup
Hi,  Ive setup a syslog server and pointed all my devices to it.  The SPA9000 & SPA400 & 4x SPA502's.  But how can i identify what device is logging what?  They all have the same hostname, My syslog server is not on the same LAN its running accross the NET.
JK
Alberto Montilla
Hi John;
I suggest you change the hostname for each device. You can also use different ports for each syslog entity.
Alberto
